This thread is privately moderated by JureZ, who may elect to delete unwanted replies.
Jun 21, 2016, 02:33 AM
Sokol
JureZ's Avatar
Great Planes Siren warmliner
Got the airframe for free at Baylands Park , with a broken wing, it needed some TLC to get in flying condition.
Many thanks , anonymous donor !
It has a 300 W in-runner motor, Kv =3900 RPM / V.
So, it operates in the ballpark of high 30 k RPM.
The propeller is a thin 5 in x 4 in
Battery LiPo 3S, 30C, 2200 mAh.
Wing span is 80 in, wing root chord is 7 in , wing area is 3.4 sqft.
All Up Weight is 45.9 oz, wing loading is 13.5 oz / sqft.
CG still needs a bit of trimming, feels nose heavy ...
Notice in the second launch, the visit of my friend the hawk .
Flying at Lariat Canyon, Walnut Creek, CA.
Great Planes Siren ,T-tail warmliner , maiden flight - Movie (2 min 36 sec)
Great Planes Siren, T-Tail warmliner, onboard video (1 min 51 sec)
Jul 05, 2016, 12:51 AM
Sokol
JureZ's Avatar
Replaced the inrunner motor I tried earlier , now with an E-Flite Power 10 , with Kv = 1100 RPM/V , 450 Watt.
Using a 10x7 APC propeller, and 3S LiPo 2200 mAh battery.
It is much quieter now than with the in-runner with Kv=3900 , and the noisy 5x4 propeller spinning at about 35K RPM.
Siren , new motor , July 4th 2016 Movie (1 min 48 sec)
Sep 04, 2016, 04:48 AM
Sokol
JureZ's Avatar
flying again, after some wing repairs ...
The E-Flite Power 10 motor shaft was pushed back (following the instructions on the manual page) ,
to reverse the prop adapter location.
Now the motor is exposed to free air.
Siren at Shell Ridge, Movie. (1 min 48 sec)
Sep 11, 2016, 07:27 PM
Sokol
JureZ's Avatar
GP Siren Spoilerons
one more configuration change:
in order to make landings a reasonable affair, programmed the two ailerons as spoilerons. Using the Gear switch , added a mix for each surface, with up deflection of about 30 degrees.
much better !!!
Oct 17, 2016, 05:05 AM
Sokol
JureZ's Avatar
now with APC 11x8 , folding.
GP Siren - Oct 16th 2016 - Moraga - Movie (2 min 15 sec)
