Jun 20, 2016, 01:43 AM
New Product
Click here! You will be interested in it!
We( COOLTECH ) are a reliable Chinese manufacturer of rc accessories such as high-end receivers, motors and ESC. Our main items are compatible Futaba receivers. Servos and UBEC are also available. Quality is what we can guarantee. Recently we launched three new kinds of receivers:
1. RSFSB--2.4G S-FHSS Compatible S.BUS output (36*19*7.5mm; 4.2g )
2. RFA04A--2.4G FASST Compatible 4CH micro receiver( 38*18*7.5mm; 3.8g)
3. RFASB--2.4G FASST Compatible S.BUS output for FPV Racing Drone Model (29*19*7.5mm; 4.2g)
I will post their information in next thread. Keep attention!
Jun 20, 2016, 04:13 AM
Nick
I would like to see some pictures of your receivers
Aug 21, 2016, 09:22 AM
i am interested in RFASB--2.4G FASST Compatible S.BUS output for FPV Racing Drone Model (29*19*7.5mm; 4.2g)
may i have more information?
Aug 23, 2016, 12:51 AM
Information
Hello, sorry for my late reply. The following is detail information:
SPECIFICATIONS:
Passageway: 1ch
Adhibition: Fixed wing/Helicopter/gliders/Car/Boat
Frequency range: 2.400GHz-2.483GHz
Decoding mode: PPM/PCMS 1024/PCMS4096
Working Temperature range: -10~+80℃
Input voltage: 3.5-8.4v
Antenna Length: 145mm(5.65in)
Weight: 4.5g(0.16oz)
Receiving mode: FASST
Output signal: RSSI&S-BUS(1CH~16CH)
Servo Frame Rate:14ms (mode FS) / 7ms (mode HS)
FEATURES:
1)Compatible with FASST 2.4G:Air Systems(7CH Mode/Multi Mode)
Surface Systems(C1 Mode)
2)Two selectable failsafe setting options
3)Improve capability of anti-interference
4)Firmware upgradable
5)Failsafe function
6)Super light weight and long receiving range(high receiving sensitivity)
COMPATIBLE:
FASST 2.4G Air Systems(7CH Mode/Multi Mode):6EX,7C,TM-7,TM-8,T8FG,T10C,
TM-10,T10CG,14SG,T12Z,T12FG,TM-14,T14MZ,etc.
FASST 2.4G Surface Systems(C1 Mode):3PK,4PK,etc
PACKAGING:
Blister size: 145mmX90mmX20mm Weight: 28.2g
Carton box size: 470mmX250mmX210mm
120sets/1CTN Grossweight: 3.8kg
Aug 23, 2016, 04:55 AM
SPECIFICATIONS:
Passageway: 1ch
FEATURES:
5)Failsafe function
COMPATIBLE:
PACKAGING:
Thank you,
Could you tell me,
Please, what is the range of this receiver?
Where can I order it for a best price?
Thank you
Aug 23, 2016, 09:40 PM
Reply to Question
Thank you,
Could you tell me,
Thank you
Hello,
The range is about 1.5km. Safe distance is 500~800m. If you are an individual buyer, you are suggested buy from here: http://www.banggood.com/Cooltech-RFA...p-1073345.html.
Mar 15, 2017, 09:55 AM
Is RSSI an analog or PWM?
Jul 18, 2017, 10:28 AM
No RSSI signal
HELP
I got a BFF3 board with betaflight 3.1.7, solder the rssi signal cable from the RX to the rssi pad on my FC, in betaflight i set the rssi channal on number 1 and no signal... not on any channel...
Whats the problem ? Do i something wrong ?
Aug 14, 2017, 04:10 AM
Simple is the best
What is the RSSI specification of this RX?
Manual not includes any RSSI information?
Sep 25, 2018, 06:02 AM
Hi, I'm having some troubles trying to bind this Rx with my Futaba 14SG. The point is, I'm probably confuse, so I'd really appreciate your help with this: as far as I understand, in order to link my Tx with and Sbus Rx I should use function system options FASSTest-14CH or FASSTest-12CH. However, when I try to link the Rx with any of those system option I get a solid red light and a green solid light, which means the Rx is waiting to be bound. The only way I success linking the Rx (single solid green light) is with FASST-7CH or FASST-MULT system options. This is the way it's supose to be? Thanks for your comments.
