This thread is privately moderated by BarnstormEddie, who may elect to delete unwanted replies.
Jun 17, 2016, 12:41 PM
Trader Rating: 6
$15.00 USD
Buyer pays shipping
For Sale
MRC Super Brain 977 Pro AC/DC Dual Output Delta Peak charger with discharge capabili
This is the MRC Super Brain 977 Pro AC/DC Dual Output Delta Peak charger with discharge capability. For radio control (remote control, RC) planes, cars, helicopters and boats as well as starter box batteries and transmitter and receiver batteries, the newest addition to the ‘Super Brain’ family of chargers, the 977 Pro offers the latest technology with many features for those who want more control over their batteries. With discharge function and dual outputs it can charge two batteries (of the same or different voltages) simultaneously. Charges NiCd, NiMh and Lead acid batteries, and 1-9 cells of any capacity.
This powerful charger also has the ability to deliver 5.0 amps per channel when using DC input or the supplied 10 amp power supply. Now you can charge two batteries of different voltages or types simultaneously, or charge one battery while discharging another. For pro users, the 977 Pro has a variety of settings for optimal charge.
Super Brain's patented MicroPeak Detection technology continuously monitors the status of the battery without having to pause periodically to detect delta peak. This ensures a linear, uninterrupted, fast charge, and avoids overcharging. Your battery will run longer and last longer. Charger and battery remain considerably cooler, allowing you to use the charger immediately after completing a charge. Super Brain 977 Pro includes the following features:
• AC/DC delta peak charger with patented MicroPeak Technology
• Dual independent outputs for added versatility
• Charge two batteries at the same time, even if they are different!
• Discharge function allows you to get the most out of your batteries
• Charge and discharge at the same time (discharge on channel A only)
• Charges NiCd, NiMH & Lead Acid batteries
• Large LCD screen shows: Battery Status, Battery Voltage, Charge Rate, Peak threshold in mV, Capacity in mAh, Number of Cells in Pack & Elapsed Time in minutes
• For 1~9 cells any capacity battery (NiCD & NiMH)
• Selectable charge rate with 0.1 amp increments from 0.20 to 5.0 amps
• Selectable discharge rate with 0.1 amp increments from 0.20 to 4.0 amps
• Selectable delta peak voltage thresholds in 5mV increments from 5 to 50 mV
• Cooling fan keeps components cool for continuous charging
• 12-bit Analog-to-Digital converter greatly improves measurement resolution
• Digital Signal Processing filters out noise and improves voltage accuracy
• MRCs patended MicroPeak technology keeps batteries cooler
• Comes with a 13.5V DC 10.0 amp power supply!
Charger is tested and work fine will come with brand new charge leads for the A channel, I do have instruction sheet printed Thank you for looking
