This thread is privately moderated by goebish, who may elect to delete unwanted replies.
Jun 05, 2016, 04:31 PM
I Void Warranties
goebish's Avatar
Mini-HowTo
How to upgrade Flysky / Turnigy iA6B RX to firmware 1.6 with a ST-Link
How to upgrade Flysky / Turnigy iA6B RX to firmware 1.6 with a ST-Link (Windows):
Use this procedure at your own risk
  • Download and install ST-Link driver:
    http://www.st.com/content/st_com/en/...oftware-scroll
  • Download ST-Link Utility:
  • Connect the iA6B to the ST-Link:
    - connect a gnd pin of the receiver to gnd on the ST-Link
    - solder wires to CLK & DAT pads inside the RX then connect them to the ST-Link SWCLK & SWDIO pins:
  • Power the RX with 5V though a servo output pins then connect the ST-Link to USB
  • Launch ST-Link Utility
  • Set the Address field to 0x08000000 and Size to 0x8000
  • Click Connect to the target ()
  • Click Save () to keep a backup of your firmware, just in case ...
  • Download TGY firmware 1.6 for iA6B:
    https://www.dropbox.com/s/ykrm7av00g...B_1.6.bin?dl=0
    optional: open it in an hex editor then change the 4 bytes at offset 0x1C00 (12 34 56 78) to change RX ID, I think you can use any arbitrary values, just avoid using FF FF FF FF
  • Click open () then select the 1.6 firmware file
  • Click Program Verify (), check that start address and file path are correct, then click start
  • Click Disconnect ()
  • Unplug ST-Link from USB, disconnect it from the RX
  • Rebind the RX to Deviation
  • You should now see RSSI in dB in telemetry monitor screen (~ -60d)
Discussion thread:
http://www.deviationtx.com/forum/pro...sed-i10-i6-it4
