New Product
55mm EDF fan nacelle
This fan nacelle fits a 55mm duct but since the inlet is tapered there is some "fudge room".
this category seem to be the best fit this product and I only tooled up for it because I have others on the website ( 90mm, 70mm. ) I think I'll test it on an EDF striker so it will look like a bobcat. The shape would look right on a scratch built A-10 , 737 or 757. At any rate its better than simply strapping the fan unit to a plane. Here is the link to the site. |
Its not too hard to assemble since there are only three parts.
You start by marking the trim lines. I would mold the lines into the part but that would surely make it hard to see. pencil marks are much easier. Rough trim the nacelle sides with scissors. Lay a sharpened pencil on its side and mark the side that does not have the step. molded in step. |
The next trim line is the inlet ring.
This time place the pencil on a piece of 1/8 inch stock. I used light ply here. |
Trim some of the forward end of the nacelle halves away to avoid a poor fit of the inlet ring.
I took off 1/4 inch . Bond the nacelle halves together at one seam only using model airplane cement. |
install the inlet ring and spread the halves to check that the edge meets the step in the second half.
You should be very close. A little block sanding should be all you need. The rest is up to you. In the past I have bonded the fan unit to the inlet ring then used silicone to bond the ring to the nacelle. When I modify my striker I'll be back to show how I managed the nacelle. |
