May 27, 2016, 06:30 PM
Mini-HowTo
Charging Mod for Cheerson CX-Stars (aka Floureon FX-10 and DHD D1)
The CX-Stars is an insanely fun to fly quad that fits inside the transmitter, which can then fit in your pocket. However, the quad can't be charged through the transmitter, it uses a special USB cable that goes straight from a USB port from whatever to the quad. To mod this quad to perfection I decided to build in a charger into the transmitter.
Description: Name: cable.jpg
Description: Name: new final.jpg
Description:
Materials needed:
Tools Needed:
  • Soldering iron
  • Solder remover (solder wick or solder sucker)
  • Hot glue gun
  • Wire
Steps
1. Remove the plastic case around the charging circuit
Name: four charger pics.jpg
Description:
2. Desolder the usb plugs off the charging circuit and the DC-DC converter
Description: Name: desoldering usb.jpg
Description:
3. Solder the two boards together, with wires between + and -
Name: soldering two boards together.jpg
Description:
4. Take case apart by unscrewing four screws, and make hole in case for switch, and hotglue switch in place
Name: inside original case.jpg
Description: Name: switch.jpg
Description: Name: hole in case.jpg
Description: Name: switch in hole.jpg
Description:
5. Place the board under the switch and solder the switch and board together to batteries, as shown in the pic (leave 3rd pin on switch empty)
Name: board placed in case.jpg
Description:
6. Remove some plastic on the case as shown in the pic
Name: before and after plastic opening.jpg
Description:
7. Cable tie extra wire from the charging cable, or just cut and resolder to make it shorter
Name: cable tieing wire.jpg
Description:
8. Unscrew the two screws holding the large circuit board on the controller
9. Remove the circular plastic piece that does not have any function
Name: extra plastic button removed.jpg
Description:
10. Run the charging cable through the hole, and screw the board back on, then screw the two sides of the controller back together
Name: wire coming out hole.jpg
Description: Name: complete.jpg
Description: Name: complete side shot.jpg
Description:
And you're done! You should see a red LED when the switch you installed is turned on, and then a 2nd red LED when you plug in the quad to charge. The 2nd red LED should go off when the quad is done charging. If you can't see the LED through the plastic, just drill two small holes in the back over the LEDs. If you are concerned about the AAAs running out too quickly, grab a couple energizer ultimate lithium, which last around 5x as long as alkaline.
Another mod that has been done to this quad is increasing the range by adjusting the antennas. See the 2nd post of this thread for more info https://www.rcgroups.com/forums/show....php?t=2518729
Let me know if you have any suggestions for improving this mod!
May 28, 2016, 10:59 AM
To make it a little cleaner I put the green plastic piece back in, but with a small hole for the charging cable to feed through.
Name: new final.jpg
Description:
Jun 08, 2016, 09:48 PM
Note that it is also sold under the name Aerix AERIUS and SKEYE Pico, although those companies are charging twice as much for their brand's version, so don't get scammed. Current cheapest shipped from US seems to be banggood at $15.50 http://www.banggood.com/D1-Drone-Min...-p-986728.html
