Jul 04, 2016, 07:08 PM
Dave Raines
Lemmiwinks's Avatar
Can you bypass the Naze and hookup the camera to the vtx?
Jul 04, 2016, 07:10 PM
Triad of Fun
WilliamSettle's Avatar
The camera has a 4 pin connector on both ends and the VTX has a 6 or 7 pin connector so not compatible unfortunately.
Jul 09, 2016, 07:53 PM
k5nwz's Avatar
Does anyone have a or know of a step by setup guide for this thing? Im having trouble getting it to see my DX8. The satellite bound but I cant get the board to show any movement from the controls.
Jul 09, 2016, 08:01 PM
Dave Raines
Lemmiwinks's Avatar
Does it register movement in CleanFlight?
Jul 09, 2016, 09:11 PM
k5nwz's Avatar
Thanks for your reply. It is bound but there is no movement in clean flight
Jul 09, 2016, 10:26 PM
Dave Raines
Lemmiwinks's Avatar
But the board is definitely talking to CleanFlight?
Jul 09, 2016, 11:44 PM
k5nwz's Avatar
Absolutely. I am able to configure it. Just can't get radio to work.
Jul 10, 2016, 08:56 AM
k5nwz's Avatar
Thanks for all of the info. Do you recall the firmware version? I wonder if thats my problem. The receiver is bound to my DX8 but there is no movement in cleanflight
Originally Posted by WilliamSettle
I just flew the S250 Pro and it flies great. It really is a bind and fly, kindof...
Here is what I did to get mine in the air:
1. Left the props off
2. Bound the Rx to my DX8. Some previous posts will help you with that.
3. Downloaded the cleanflight plugin for Chrome and started it up
4. Plugged the Naze32 controller into my computer via a USB cable from my cell phone
5. Cleanflight automatically connected to it after the USB driver was auto-installed
6. Followed the 4 minute video above to make sure my throttle, yaw, roll and pitch controls were correct. I had to reverse my yaw channel and cleanflight made this very easy for me to see.
7. The video also makes a very important point about the value of the throttle and yaw to make it arm. I had to increase the endpoints a few percent to make it arm for those two channels.
8. I was able to arm the S250 then went to the tab that test the motors. It was cool to be able to spin them up individually.
9. Put the props on and flew it.
I did not mess with with upgrading the firmware and it flies fine as is.
I was also confused as to why there was not any instructions in the box on how to set it up. It took me several hours of research yesterday but in the end, I figured it out. Hope this helps someone else.
Jul 10, 2016, 01:09 PM
Dave Raines
Lemmiwinks's Avatar
Hmmm...check the UART settings, maybe its mis-configured for a Spektrum satellite. You could also try another satellite to see if thats the problem
Jul 10, 2016, 02:02 PM
k5nwz's Avatar
Yes, I checked that. It won't let me change it as it automatically detects the satellite. I do have another satellite I can try
Jul 10, 2016, 02:54 PM
k5nwz's Avatar
I have even disconnected the satellite completely and it will not let me change any setting relating the receiver
Jul 10, 2016, 04:23 PM
Triad of Fun
It's in a previous post... https://www.rcgroups.com/forums/show...6&postcount=37
One thing different, my DX8 is a G2.
Jul 14, 2016, 02:25 PM
k5nwz's Avatar
Does anyone know how to switch the FPV transmitter from PAL to NTSC?
Got it flying! Now I need to be able to see...
Thanks for all the help.
Jul 14, 2016, 02:28 PM
Dave Raines
Lemmiwinks's Avatar
You need to switch the camera not the Vtx.
Jul 14, 2016, 02:47 PM
k5nwz's Avatar
Wow!. Im an idiot. I didnt even think about that.
