Aug 23, 2004, 07:39 AM
Closed Account
POP goes the battery
My 11.1v lipo just exploded in a ball of flame I was charging on a super nova 2 charger when I saw a big flash outside. Wnet to investigate and the lipo was on fire. Luckily the charger and power supply survived. What caused it I dont know. All was set correct........I think. Please be carefull when chargibg lipos
Aug 23, 2004, 07:52 AM
Molded Hotliner Destroyer
Magnum9's Avatar
Is the super nova 2 a specific lipo charger? A quick google search does not reveal any super nova charger that can charge lipos.
Aug 23, 2004, 09:12 AM
Closed Account
Yes it is designed for lipo batteries. I have used it for 2 weeks without any trouble.
Aug 23, 2004, 09:23 AM
Once again, an accident, series-charging a 3s pack.
- RD
Aug 23, 2004, 09:33 AM
Unicorn
Jay C's Avatar
Is it one of these?
I can't find a superNova 2 either. The SuperNova 250s is all I can find. A picture would be helpful.
Jay
Aug 23, 2004, 09:49 AM
Closed Account
SUPERNOVA 3000 version 2.
Battery Type: Nicad, Nimh, SLA, Li-Ion & Li-Po
Delta Peak Cut-Off: Yes
Charge and Discharge
Charge Rate: main output 1 - 30 cells/automatic or user selectable 0.1 - 5A
1 - 5 cell Li-Ion & Li-Po
Tx-Rx output 4 - 8 cells/fixed 250mah(no cut off).
Features: Zero current voltage check, low and over input battery warning, reverse polarity protection, cycle mode for battery maintenance, temperature protected against overheating & 5 differnt warning sounds.
Aug 23, 2004, 10:13 AM
Unicorn
Jay C's Avatar
Ok, found that one. wonder why it's only available in AU?
Jay
Aug 23, 2004, 10:35 AM
Space Coast USA
hoppy's Avatar
Oh, oh - "no longer available"
http://www.modelflight.com.au/rc_mod...arger_3000.htm
will keep looking, maybe that was version 1
This one is a NiMH/NiCd only - version 2 must include the lipo's
very little info available
Aug 23, 2004, 10:55 AM
Space Coast USA
hoppy's Avatar
Couple of questions -
Is it "Auto Cell count" on LiPo setting or do you set the cell count or pack charge voltage?
Does it state how the lipo's are charged? For instance, CV/CC? )Constant Current/Constant Voltage). Timed charge?
Sep 05, 2004, 09:46 PM
I am using the SUPERNOVA 3000 version 2 to charge a 3 cell lipo.
It seems to terminate correctly, but I have trouble getting it to start charging.
Description here https://www.rcgroups.com/forums/show...supernova+3000
Sep 05, 2004, 09:51 PM
Manual setting of charging voltage and current.
After charging for 1 minute it checks the battery voltage and gives an error if it is too low.
It is a CC/CV charger.
Three lead switch harness: which one goes to the battery?? arukum17 Batteries and Chargers 8 Nov 28, 2016 07:20 AM
Discussion Pop goes the Weisel AirMicro Micro Ready-to-Fly 14 Aug 27, 2006 09:46 AM
pop pop goes the nimh cell Nethole Batteries and Chargers 0 Feb 23, 2005 07:25 PM
