May 21, 2016, 05:53 PM
Mini-Review
Cheerson CX10D - Review (Courtesy of Banggood)
Hi all,
Today I will be reviewing the Cheerson CX10D. This nano boasts something never found in a quadcopter of its size yet, altitude hold, yet a camera isn't present. Its brother the CX10W, which I also own, was a bit of a hit and miss with poor control letting it down. Let's hope Cheerson's latest release fares better.
Thank you to BG Well for providing this review sample. This product is available for purchase here: http://m.banggood.com/Cheerson-CX-10..._content=73669
Specifications: (From Banggood's site)
Brand Name: Cheerson
Item No.: CX-10D
Item Name: CX-10D Mini RC Quadcopter with High Hold Mode
Diameter of Blade: 30mm
Channal: 4CH
Transmitter type: 2.4G
GYRO: 6-axis
quadcopter Battery: 3.7V 150MAH Li Battery (Included)
Transmitter battery: 2 x AAA dry battery (Not included)
Flying Time: 5mins
R/C Distance: 25m
Flying height: 25m
Charging Time: about 30mins
Material Of Product: ABSAviation Material
Size Of Product: 45x45x22mm
Product wieght: 15g
Color:Colorful,Camouflage
Features:
1. 4 channel transmitter:Ascend/Descend;Forward/Backward; Left/Right; Left/Right rotation; Throw to fly etc.
2. 6-axis gyro system makes CX-10D very stable and easy to opearate.
3. CX-10D can be operated in 3 flying modes. High/Low speed modes can be changed using a transmitter and the third mode in 360°high speed rotation mode in which the aircraft's light dazzle.
4. With high density air presure sensor which can precisely hold the height, it adopts the dual-spring control sticks.
5. CX-10D can perform 3D flips/rolls (forward/backward, left/right)
6. CX-10D can rotate to left/right while flying or hovering.
7. CX-10D is equipped with a battery protection module to protect and prevent overcharging the battery.
8. CX-10D have One Touch landing and One Touch take-off.
9. CX-10D is equiped with multi-color LED lights making the flight more spectacular especially in the dark.
Package includes:
1 x CX-10D quadcopter (with 3.7V 150MAH Li Battery)
1 x Transmitter
2 x Spare Blades
1 x USB Charging cable
1 x Manuals
Unboxing
Description:
Packaging was very good, a thick layer of bubble wrap.
Description: Name: IMG_20160522_082615.jpg
Description:
The package itself was well done, but nothing too out fo the ordinary.
Description: Name: IMG_20160522_082635.jpg
Description:
Once you get past the first layer you're greeted with a second, much more colorful one.
Description:
The package has a good structure for travel with room for all necessitates.
Description: Name: IMG_20160522_082838.jpg
Description:
Spares are stored below the quadcopter.
Description:
Everything you get...
The quadcopter itself:
Description:
Each CX10D comes with some special design, although this doesn't add to performance it really helps in the looks department.
Description: Name: IMG_20160522_083223.jpg
Description:
This drone is powered by a non-removable lipo battery, so look after it well.
Description:
The landing feet are little circles of foam.
Description:
On the back you have an on/off switch and a charging port.
Transmitter:
Description:
The transmitter doesn't fail in the looks department either, continuing with the same theme.Something to note is the transmitter is spring loaded, the throttle stick will return to the center if you let go. This makes binding more difficult but not impossible
Description:
The transmitter will require 2 'AAA' batteries to operate.
Spares:
Description:
A manual is also included and required. It did a perfect job of explaining the alternate binding and arming procedure and will probably cover most of your questions.
Description:
A charging cable is included.
Description:
4 spare propellers are also included.
Flight:
Altitude hold is defiantly something of personal preference and something to get used to. Personally I prefer no altitude hold and prefer no to little extra support from the FC. In saying this altitude hold will be something that beginners adore, making flight much more easier. Flight time is 5 minutes, average for a nano. Range is approximately 40 metres, not bad. Yaw and pitch does change as you dial up the rates, buy even at the highest rate it can't handle any wind. This is normal for a nano but limits its ability for outdoor operation.
Video Overview:
Cheerson CX10D - Overview (Courtesy of Banggood) (1 min 8 sec)
Video flight:
Cheerson CX10D - Indoor Flight (2 min 29 sec)
More to come.
Pros and Cons:
Pros:
Altitude Hold
Packaging
Looks
Rates
Price
Cons:
No way to disable altitude Hold
Awkward binding and arming procedure.
Built in battery.
Suggested Improvements:
Get rid of the inbuilt battery and make sure there's a way to disable altitude hold. If these things improve then it'll really sell.
Summary: A wonderful little nano that stands out of the background, a quadcopter that you should definitely keep an eye on.
May 22, 2016, 08:49 AM
Neat
May 22, 2016, 05:27 PM
Originally Posted by quaddiction
Neat
Yes, it's a nice nano.
May 22, 2016, 10:00 PM
Hey guys,
I found the link of this stuff above can not connect to the product's page,for your convenience ,I post the correct link of this product here, http://www.banggood.com/Cheerson-CX-10D-CX10D-Mini-2_4G-6-axis-with-High-Hold-Mode-LED-RC-Quadcopter-RTF-p-1046119.html?
Just start your crazy buying!Also ,I have contacted @DroneRequired to check out and modify the link,waiting.
Best wishes,
BG Well
May 24, 2016, 02:48 AM
Originally Posted by BG Well
Hey guys,
Best wishes,
BG Well
I've changed the link, everything should be working fine now.
May 25, 2016, 09:29 PM
Hi DroneRequired ,
Does the review is finished? No more other comparsion videos?
May 26, 2016, 12:37 AM
Hi DroneRequired ,
I will be posting a outdoor flight, overview and a video demonstrating altitude hold. I haven't been able to gather any footage though, I'm using stock due to Melbourne's weather. But yes, the text part of the review is complete.
May 26, 2016, 05:14 PM
I added a video overview:
May 28, 2016, 11:47 AM
(͡° ͜ʖ ͡°)(͡° ͜ʖ ͡°)(͡° ͜ʖ ͡°)
JohnCC's Avatar
This little guy is fun:
Cheerson CX-10D - Altitude Hold (Courtesy Gearbest) (4 min 32 sec)
