May 08, 2016, 11:19 PM
Help!
i want to build my first 130mm quad
so i want to use this setup
radio rx http://www.banggood.com/FrSky-D4RII-...-p-929069.html
video tx http://www.banggood.com/Eachine-ET20...p-1022303.html
camera http://www.banggood.com/Eachine-700T...-p-991027.html
props http://www.banggood.com/Diatone-3045...p-1028618.html
motors http://www.banggood.com/DYS-BX1306-1...p-1040415.html
esc's http://www.banggood.com/DYS-XM-Seris...p-1021885.html
pdb http://www.banggood.com/Matek-System...p-1049051.html
flight controller http://www.banggood.com/DALRC-NAZE32...p-1020774.html
would you recommend that setup for a 130 frame?(the motors are 1306 because i want the possibilityto use 3 blade props)
and i am looking for a 130mm frame that the battery will be inside the frame
and i also need your help to decide the battery i will use
thanks a lot
May 09, 2016, 01:18 AM
Someone?
May 09, 2016, 09:22 AM
SQUIRREL PATROL
inap's Avatar
130 is very small. Not sure there is a frame that size with a protected battery.
May 09, 2016, 09:42 AM
humayraykinaon's Avatar
I agree with inap, you'll not gonna find one, you either strap it on top or bottom. For that frame size, you don't need an xt60 plug, you can go for the smaller xt30 instead.
I use these pbd
http://www.banggood.com/Diatone-V5_0...p-1024389.html
