Idea
Use prop savers? I made a prop saver tool
I use prop savers on a lot of my planes. I've had bad luck with o-rings, so I know generally use a small slice of surgical tubing to hold the prop in place. This works great except ... it's really tight and fiddly to get the o-ring / tubing in place over the prop. I've used hemostats, pliers, small screw drivers. They all suck.
About a week ago, I had an idea for a different tool and, while looking for materials in a drawer, found some picture hanging hardware that I thought would work for what I had in mind. I built a prototype tool and it works great. Here's what I did. I started with a cheap picture hanger, like one of these. My original was made from a thinner picture hanger than these, but these work fine. They cost $0.97 for a 3-pack. ![]() ![]() I straightened out the hook part that's designed to hold the wire on the back of the picture. ![]() ![]() I flattened mine out in a small vice, but pliers or a hammer will do. ![]() Here's the shape at this point. ![]() Next, I add a new bend in the opposite direction from the original hook. This will only stick out 1/8" or thereabouts. ![]() ![]() Here's the final shape. ![]() I added a sort of handle by putting some shrink wrap about the lower portion of the tool. ![]() Here's the finished tool. My thinner original is at the top. ![]() I've found this to be nearly perfect for grabbing onto my o-rings, etc., pulling them into place, and then letting go of them again. ![]() ![]() FWIW |
Thanks for the tip. I use http://www.big5sportinggoods.com/sto...3#.Vy1xeOQ9aSo - you can try that out if you're interested. They've been easy to put on, yet keep the prop on firmly without the excess pressure of O-rings.
https://www.rcgroups.com/forums/show...2377142&page=2
#19 The hollow shape help a lot to install the ring as you can see in the last picture. |
I found that the o rings I get with those prop saver packs are usually so dry rotted and brittle you can't use them. I don't have any surgical tubing so I match the o ring size up at homedepot in their kitchen faucet hardware section they are a perfect replacement and much stronger than the import ones. I think I got a pack of ten for about two bucks.
Lowes Home improvement sells this tubing by the foot and a lil cheaper.
