This thread is privately moderated by John S., who may elect to delete unwanted replies.
May 06, 2016, 02:54 PM
Trader Rating: 57
$125.00 USD
Buyer pays shipping
Sold
Himax HC6320-250 Brushless Outrunner Motor. Has 3 flights on it.
Beautiful Himax HC6320-250 Brushless Outrunner Motor. This motor is basically new and Has 3 flights on it. No crashes ever. $125 Shipped
The HC6320-250 motor is made for large models weighing up to 10 Lb for 3D flight, up to 17 Lb oz for aerobatic flight and up to 22 Lb for leisurely flight. High Efficiency - High Power - High Torque - Lightweight - Replacement for 1.20 cubic inch glow or gas engines Specifications: Weight: 450g, (15.9oz), Motor only Max Power: 1700W, (This is dependent on several factors) Max RPM: 10,000 RPM Diameter: 63mm, (2.48) Length: mm, 51mm(2.01) Shaft Diameter: 8.0mm (.315) Maximum Case Temperature: 65C, (149F) Electrical Specifications: Kv = 250 rpm per volt Rm = .041 ohms Io = 1.3 amps at 20V Efficient Operating Current = 30-60A Continuous, 80A Max 15 seconds Recommended Accessories: 80 Amp Brushless Speed Control 9-12S Lithium Polymer or 27 to 36 Cell NiCd or NiMH Battery, capable of 60-80 Amps Operation:
