This thread is privately moderated by jmxp69, who may elect to delete unwanted replies.
Feb 27, 2017, 11:42 AM
Apologies for stealing someone's answer but I was buying some of this the other day. It's Spiral Wrap. As a guide 1.5mm thickness covers wires of thickness 2~15mm roughly. I use very thin stuff and it will stretch quite a bit.
May 11, 2017, 11:56 AM
Did you notice poor GPS performance having it sitting on top of the dragon link rx?
I have a similar setup and I am fighting with GPS fix issues.
May 23, 2017, 09:40 AM
I solved my problem by switching vtx frequency from 1280 to 1360.
Jul 12, 2017, 07:35 AM
JamDan's Avatar
Very nice build. You've given me some ideas for my own Talon. What type of black paint did you use on the tails? The paint has a very nice matt finish to it, I think I'd like to use some too
Aug 21, 2017, 03:45 PM
jsa
jsa
jsa's Avatar
How does it fly?
Very nice X-UAV Build - How does it fly?
Aug 21, 2017, 10:55 PM
jmxp69's Avatar
Originally Posted by phoanglong
great build jmxp69,
by the way, i will be using 1.3Ghz system for FPV and 433Mhz for controlling, should i get Low pass filter? And is it necessary to get the Air Speed Sensor as well?
I'm a newbie when it comes to long range (first build) so any suggestion is greatly appreciated.
Many thanks,
Long
I use Racewood 1.3ghz VRx and they do not require any filters. I think it's a good idea to use AS sensors if you're going to fly distance because you'll want to know if you're getting a headwind or tailwind. Important for managing flight time. i.e. Fly upwind on the way out, fly downwind on the way home.
Originally Posted by schlickmann
@jmxp69 excellent work in your MT.
You have the files of your wood stand? I really love them.
With these stands are easy to build a MT.
Actually bought that from Hobbyking some time ago. Here's the link.
Originally Posted by Axiom7
What is the name of the split clear plastic that you have on your run cam and servo wires from your pan and tilt
I'm not sure where I got it, but I think it was Amazon. Here's a link.
None. The Rx antenna is behind the GPS. Full disclosure though, I moved out of Arizona so no longer have the desert and never took this plane for a long flight. My Twin Dream plane has the same setup and works great but the Rx antenna is farther back.
Hmmmm...good
Krylon Shortcuts Flat Black. I get it at Michaels.
Pretty good. Takes a little while to get used to hand launching a fully loaded plane designed for efficiency, but it does fine.
TestFlight - Mini Talon Build Review and Maiden Flight (10 min 2 sec)
Aug 24, 2017, 07:57 PM
JamDan's Avatar
Great thanks, I'll pick some up.
Jan 27, 2019, 08:02 AM
็How do you mount the rear motor?
Mar 13, 2019, 05:29 AM
Hi my friends
Very Nice Video
TURKIYE
ANTALYA CITY
MANAVGAT TOWN
Fpv Takip (3 min 55 sec)
