Apr 30, 2016, 08:24 AM
EndOfDays's Avatar
Yippee!
151min30sec flight-time with Copter (FPV)
Hello over here ...
since quite a while I am working on a new personal best with my copter, but today I manages that I get a reasonable flying time together with all SD-Cards are working, all SD-cards have enough space, all involved devices and their batteries are working, and finally the weather conditions are - well - useable.
Result:
151min30sec
2h 31min 30 sec flying-time
The flight plan was to fly with an average speed of 20-30km/h in big circles, but unfortunately the wind raised during the flight up to 20km/h so that the second half of the flight was done in hover only.
Here the details of the copter
DIY Frame with 20mm square CF rods (HK)
ESC: Hobbyking 30A
propeller: Foxtech surpreme 28"
FC: Naza V1
FPV: HD-cam + 5,8Ghz VTX + EXTiny
Copter about 1900gr
Battery about 4200gr
AUW : 6100gr.
Akku 6S8P GeBattery means 6S48000 on paper, during the flight I used 44000mAh
Onboard video in editing, but here some pics:
Since I had plenty of time, and time was really passing slowly, I could do some material for a teaser:
151min 30s FPV Teaser (0 min 31 sec)
best regards
Ferdinand
Apr 30, 2016, 11:30 AM
EndOfDays's Avatar
Here the FPV-Video with timestamp:
151min30s FPV with Copter (7 min 1 sec)
best regards
Ferdinand
Apr 30, 2016, 01:43 PM
g/w=17
congrats
Apr 30, 2016, 02:27 PM
Always Excel >>>
BenHayat's Avatar
Don't you loose efficiency when props facing down and the motors do not cool off as if the props facing up? For example, in X8 configuration, the bottoms motors get more hot.
May 01, 2016, 02:57 AM
EndOfDays's Avatar
@BenHayat,
The motor do not heat up (possibly 1-2C above ambient after flight).
best regards
Ferdinand
May 23, 2016, 02:37 AM
wooo Great Congratulations , is that 100kv ?
May 23, 2016, 04:20 PM
EndOfDays's Avatar
135kv
May 23, 2016, 06:35 PM
Pilot In Command
HelihoverAP's Avatar
Very cool!
Aug 27, 2016, 12:06 AM
is there any way to increase the efficiency of coaxial setup ?
Aug 28, 2016, 04:52 PM
You might lose a little efficiency from the prop because the airflow is disrupted by the structure and the motor versus a tractor configuration. However, in a tractor configuration you end up with the prop thrust hitting the structure which negates some of the thrust (Newton's law). In a pusher configuration the airflow just in front of the prop (where the motor is) is accelerated by the prop thrust (low pressure fill to replace the air moved by the prop) such that the airflow just before the prop is pretty much the same as just behind (if it is not, the prop will stall). Therefore, it doesn't really matter whether the motor is in front of the prop or behind as far as cooling goes (if you have direct drive props/motors).
Oct 29, 2016, 07:20 PM
Learn to fly with thumb..
Great !!
Could you please share the detail info on the battery?
Do you have the build log Ferdinand?
Oct 30, 2016, 04:50 AM
EndOfDays's Avatar
Battery is a GE 6S8P of 6100mAh cells (GEB 8043125), just the same as in the 129min flight 3 year ago, but double the amount.
There is the thread befor this flight and some pics about the mods:
http://fpv-community.de/showthread.p...zeitflug-wurde
best regards
Ferdinand
Feb 07, 2018, 07:48 AM
Navio
Could this be fitted with Navio2 and no cam instead? And carry a 200g payload? Maybe a little faster instead of extreme duration? Maybe like down to 50 minutes?
Best Regards
Negan
Apr 16, 2020, 06:12 PM
Quadaholic
--Oz--'s Avatar
I fellow rcg'er posted this, 190 minutes
World Record Flight 190 min electric multicopter (10 min 38 sec)
