I've come up with a unique way to install these servos into a wing that will tie the top and bottom wing skins together and allow you to remove the servo without braking them out. Check it out.
![]() ![]() ![]() Merry Christmas, Jim ImagesView all Images in thread
Wow that's pretty nifty Jim!
Latest blog entry: F3J on the Back Burner
Nice one of the best I have seen, third hole really makes it work. Did you consider threading the center hole?
I didn't consider threading the center hole because my standoffs were already threaded so I used what I had. However, if you did it that way it would make removal a little easier. Either way will work better than gluing something to the servo and wing skin.
Just wanted to give some HV6130 feedback now that I have some time on them. I installed them on the ailerons and outer flaps of my 130" span Transonic DP using aluminum frames with 3rd bearings and they have performed flawlessly! DSing at 467mph is asking alot from such a small servo but they are working out great. I'll give another update farther down the road regarding durability and wear...
Great report! I was skeptical at first but they are really proving themselves. Love those frames too.
Latest blog entry: JW48 - Lightweight DS Build
Hi Soarmark,
I am CNC cutting the frames in my garage from 7075. I'm selling them for $40/pr. I like the rigidity of aluminum and designed the frames to maintain the very small footprint of the 6130. I also have a bunch of the Smartmodel frames for the DS6125 and HBL6625 as well as the KST immitations for $37/pr. You can email me at: [email protected] if you want some. |
I purchased some of these frames to outfit an Afterburner (2m DS sailplane). Spencer has done a nice job with with the frames. They are very compact and the fit is excellent, making use of the 6130's third hole. A nice touch is glue "cleats" on the perimeter. I was super excited when I was tipped off by Killercando (Lee) that Spencer had these available. If you need short aluminum MKS servo arms Spencer has those too.
Confirmed that these servos are really frugal on consumption. After a full day of f3f, my 18650 liion pack took only about 200mah to charge full. I am thinking an 18500 pack would be totally adequate, and make some precious space available...
In Jim Fram's photos, instead of screwing the cross brace to the standoff, you could get rid of the cross brace and simply screw through the hatch cover. Build up the underside of the cover and you could use a countersunk screw. Layup a thicker hatch cover if you need more stiffness.
Looking for a little help, I just purchased a set of the HV6130H servos along with a set of long metal servo arms for a turbine jet that I'm starting to build. It looks as though the long arms will be to short for the elevator application. I have looked long and hard and can't seam to find the output spline size information. Size and number of teeth. Can anyone tell me the size and who may have an aftermarket servo arms?
Thanks, Robert |
