Jul 26, 2016, 05:54 PM
deewc74's Avatar
What receiver is recommended for spectrum Tx?
Aug 11, 2016, 08:54 AM
vtx and FC
the vtx can be upgraded for one with changeable antenna's for about 18,
the usb drivers my need stsdrivers installing
does anyone know where to purchase a replacement FC for this, as mine got a little crispy when I pulled an inverted flip
Aug 23, 2016, 10:53 PM
foxtechtech's Avatar
Size for Tarot 130transmitter
The size of the transmitter(TL150F1) that matched with Tarot 130 is 36*19*7(L*W*H/mm), weight 4.5g each. You can check the pictures of How they look together from the link: https://www.foxtechfpv.com/tarot-130...ver-combo.html Hope this would help while you chose transmitter's size.
Latest blog entry: FOXTECH GAIA 120 Hexacopter
Aug 31, 2016, 11:46 PM
An-Lone's Avatar
Which receiver to use for Spektrum radio transmitter
I have the same question, can you recommend a receiver that will be able to use in the TL130H1 quad that can bind to my Spektrum Dx8? If you can provide some guidance on how to connect the recommending receiver to the FC. Thanks in advance!
Dec 27, 2016, 05:42 PM
Not good looking but necessary (for me)
Jan 15, 2017, 01:15 PM
FC is out in the market
http://www.banggood.com/Eachine-Race...tml?rmmds=cart
Mar 06, 2017, 11:11 PM
haha, I bet it doens't survive a crash
Mar 10, 2017, 07:54 AM
It was a bit flimsy ;-)
I upgraded to 1306 Motors and mounting the cam in the middle of the quad with a small metal bracket. Works fine now :-) (see the other thread about the 130 Tarot)
Apr 11, 2017, 03:39 AM
Jay92's Avatar
Since I don't have a low capacity 3S battery on hand now, so could i use my 2S 7.4V 700mAh battery instead?
Apr 12, 2017, 02:43 AM
Flyawayyy's Avatar
if you do not intend to fly fast or are just learning the ropes, a 2-cell battery will suffice. Tarot actually recommends fitting the 130 with a 3S 450mAh 35C Li Po for best performance.
Apr 21, 2017, 10:30 PM
Jay92's Avatar
this small quad could fly over 10 minutes with a 3S 800mah lipo, even longer than those bigger quads. cool!
May 03, 2017, 03:49 AM
Flyawayyy's Avatar
could foxtech provide some extra prop ,i want to get some new propellers for my tarot 130
May 05, 2017, 03:05 AM
yes the tarot 3inch propeller is in stock now, the link is https://www.foxtechfpv.com/tarot-3in...cs-cw-ccw.html
May 10, 2017, 03:34 AM
my clean flight upgraded, but Tarot 130 can't be upgraded. how to do ?
May 12, 2017, 04:01 AM
Flyawayyy's Avatar
Tarot 130 can't match the update version of clean flight
Discussion Tarot 130 FPV Racing Quadcopter PNP Combo foxtechtech Micro Multirotor Drones 211 Sep 09, 2017 03:18 PM
