Jun 15, 2016, 11:39 PM
When you mention manageable, do you mean it's working just fine without any issues?
You can get the same ESCs here for $6 a piece shipped:
http://www.aliexpress.com/item/Hot-S...660060320.html
Originally Posted by sirfrancis168
i totally took of my quad, since the support is lame,
i cant wait for another email
i replaced mine with standard naze and blheli 10amp one shot,
ubec,
still manageable
i think this is the last time i will take some of their drones
Jun 15, 2016, 11:44 PM
More jets than a carburetor
skydve76's Avatar
Are the stock escs ok?
Jun 16, 2016, 12:37 AM
first time I saw the topic the ESC are not
its better to replace them, with and ESC im familiar with
blheli oneshot 10am,
Jun 20, 2016, 02:04 AM
Originally Posted by G2loq
Hi, what are the 3 wire male plug used to connect the s-bus or the camera to the Naze 32 on this model ? molex 1.25 ? Other ?
Thanks in advance
Hi friend, it is the same as servo's male plug in landing gear
Jun 20, 2016, 02:05 AM
yes, esc in stock is ok
Jun 20, 2016, 02:08 AM
i drove to the shop of a friend that has,, and yes his USB works,
with the same driver i have
detected automatically,
but when he used my USB for his computer. it doesn't work
i guess i got the lucky defective USB out of the box.,
may I have your email or send a email to [email protected]? Foxtech will resend a new USB
Jun 20, 2016, 02:16 AM
ubec,
still manageable
hi friend, would you describe the detailed problem to [email protected] , the engineer will help you.
Jun 20, 2016, 07:36 AM
G2loq Chopper
G2loq's Avatar
My question was clear but it seems to be impossible to have the right answer !
Thanks in advance
I need to know the name because I need to buy some of them.
Anyway... A landing gear in the Tarot 130 ???
Jun 21, 2016, 05:59 PM
For those who may have bricked their Naze board on Tarot 130.
There's a button on the bottom that you have to use to put it into flash on boot mode.
I used CF configurator 1.2.2
Using their USB dongle go to Firmware Flasher.
Select
No reboot sequence
Flash on connect
Full chip erase
Manual baud rate 256000
Press and hold the button then plug USB in while holding it and keep holding button pressed.
Select your FW file and press Flash Firmware button.
I was able to flash it with Betaflight 2.8.1
Jun 24, 2016, 05:27 PM
thanks so much....
I was trying something like that...but not exactly on same way.
Mine was death, and now it is alive again and running betaflight
TAROT TL130 H cleanflight air mode enabled ( comentarios en español ) (2 min 34 sec)
Jun 27, 2016, 04:59 PM
and FPVview
Tarot 130 stock camera FPV (1 min 52 sec)
Jul 01, 2016, 02:02 AM
Select
No reboot sequence
Flash on connect
Full chip erase
THIS GUY SAVE MY QUAD!!!!!!!!!!!!!!!!!
Thank you sir.
Jul 04, 2016, 10:32 AM
Thats good to know, i hope the usb will arrive soon,
Jul 07, 2016, 07:00 AM
I see vibration on FPV video feed. Can someone give suggestions how to improve it?
Jul 23, 2016, 06:52 PM
No answer since days... Is it a dead forum ? Or foxtech guys are too busy working on their Screamer I'am also waiting...
sorry G2loq, I think my staff missed this thread, and I think your problem was already solved?
Discussion Tarot 130 FPV Racing Quadcopter PNP Combo foxtechtech Micro Multirotor Drones 211 Sep 09, 2017 03:18 PM
