Apr 24, 2016, 02:10 PM
Replacing frsky xsr soldered antennas
Is it possible to replace the soldered on antennas of the frsky xsr receiver?. Any tips? I have one of these receivers on the way for a new build and just want to know incase one gets cut
Apr 24, 2016, 03:13 PM
FA3PR9WM79
Oldgazer's Avatar
Its possible but....
Working with small gauge coax can be a real PITA, and if you're not careful when you are soldering the braid you can melt the dielectric core and short the signal to the shield.
Also, the working distances tend to be short, pad distances close, and pad size small, so you need good lighting, some form of magnification, a fine tip temperature controlled iron, and very steady hands.
Thanks to an inherited Essential Tremor in my left hand, I have every thing but the steady hands. Most likely I could do it but it would take me a while to get every thing setup...
May 16, 2016, 09:38 AM
xsr antenna broke
Hi Guys,
Any idea where to get replacement antenna's? i broke/cut both of them in a crash and need to replace them now..
Jun 21, 2016, 07:38 AM
I also need some recent crash chopped one any ideas where to get them?
Jun 21, 2016, 08:54 AM
mntbkr's Avatar
Knock on wood I haven't damaged mine but I'm interested in this topic just in case.
Something clever goes here...
Jun 22, 2016, 05:19 AM
Mitty996's Avatar
Same boat here. Google found me this video. Looks like regular Rx antenna from Amazon. No mention of the 90mm length of the stock antenna. Must not matter.
How to replace antennas on FrSky XSR (7 min 23 sec)
Dec 07, 2016, 01:37 PM
ps915's Avatar
FrSky U.FL Antenna Mod
I did this U.FL Mod.
Dec 07, 2016, 05:10 PM
Extreme Superlative Hyper-Pro
Moto Moto's Avatar
Nice. Are the pads laid out for the U.FL connectors?
Dec 07, 2016, 06:52 PM
Where did you get those little connectors?
Dec 11, 2016, 11:02 AM
metropolis's Avatar
I'd be interested in knowing more about the U.FL mod as well!
Dec 12, 2016, 02:29 AM
I have some of these connectors coming, I'll do a short video on the soldering to the xsr if they turn up this week before I go away
Dec 12, 2016, 02:20 PM
Awesome mod! Is this as easy as it looks? How's the signal compared to default?
Will these work? http://www.digikey.com/product-detai...1CT-ND/2135256
Dec 12, 2016, 06:59 PM
That looks like them, I got mine from here
http://www.aliexpress.com/item/32583...583342251.html
I ordered mine Nov 16th, hope they come soon.
Jan 30, 2017, 04:40 AM
hello ,
I already changed my antennas on my XSR. And one just ripped off , the pad where the center of the coax was soldered on just went with the entenna..
So I have 2 questions , as I think I can't use the left antenna pad anymore :
1 - Why is ther 2 antennas ? are they the same ?
2 -If they are,, could I just solder the two on the same pad ?
3 - "Why just bother ? just buy an other one !"
Jan 30, 2017, 07:38 AM
My quadcopter is not a drone!
unseen's Avatar
Originally Posted by boubou13100
hello ,
There are two antennas because one is used to send telemetry back to your radio and the other receives the signal.
So your answer is 3: Buy a new one.
