BAYANGTOYS X16 With altitude Hold - Brushless motors - Page 4 - RC Groups
May 14, 2016, 10:51 AM
Fan of just about anything RC
SoloProFan's Avatar
Doesn't that sound more like an ESC issue? A brushless motor can't turn unless the ESC "fires' the coils in a certain order and frequency. If the motor spins up uncontrollably, the ESC must be commanding this. You can test by swapping 2 motors, and see if the problem moves with the motor, or stays on the same arm.
May 14, 2016, 11:02 AM
Originally Posted by SeByDocKy
Probably the motor ....
Motor start to spin then when throttle up gently start to spin at max speed ....
It looks very similar to motors DJI 2212 / 920KV
May 14, 2016, 11:31 AM
SeByDocKy's Avatar
Yes ... I have no choice ... but I don't want to spend billion hours to fix it. Anyway was the ESC with a desoldered connexion. I don't think I killed the ESC when resoldered it ...
Latest blog entry: Youbi XV-130 130MM FPV Racer
May 14, 2016, 12:04 PM
SeByDocKy's Avatar
Bayang X16 interior
Bayang X16 interior (1 min 35 sec)
Problem
Bayang X16 problem (0 min 14 sec)
May 14, 2016, 12:10 PM
SoloProFan's Avatar
Could also be a gyro issue, if the board thinks that arm is dropping, it tries to correct with increasing throttle. So best test would be to first swap motors, see if problem moves with motor. If it stays on the same arm, it's either the ESC or the board's control signal to the ESC, being wrong. Swapping the ESC on the affected arm with one from a arm that behaves ok, is the next step. If the problem still stays on the same arm, it's the receiver board, if it moves with the ESC, it's the ESC.
May 14, 2016, 03:15 PM
SeByDocKy's Avatar
It's the ESC ....
May 14, 2016, 03:23 PM
SoloProFan's Avatar
Better than the receiver, but it's still a bummer. Can you see anything wrong with it? Maybe replace the FETs?
Btw, isn't it weird the ESC on the arm that gived the problem is also in the wrong spot? The other 3 are on the other side of the arm, this one breaks the symmetry. Looks like a poorly assembled one, was this a prototype maybe? GB doesn't even have it in stock yet, even when they are usually pretty fast with BayangToy stuff.
May 14, 2016, 03:31 PM
SeByDocKy's Avatar
May 14, 2016, 03:38 PM
SoloProFan's Avatar
Those wires seem almost pasted on, solder hasn't flowed at all. The ESC is also led-bar, right?
May 14, 2016, 03:43 PM
SeByDocKy's Avatar
I redid the soldering job no improvement.
Yes there are some LEDs but not functionnal...
May 15, 2016, 12:39 AM
SeByDocKy's Avatar
Seems it's working again ....
(if 100% confirmed), I am asahme to say how I fixed it
May 15, 2016, 12:47 AM
SoloProFan's Avatar
Good to hear that, and we all overlook things from time to time, so I won't laugh. Maybe chuckle a little, but hey, better have people laughing about you, than crying over you, right?
May 15, 2016, 01:00 AM
SeByDocKy's Avatar
In any case, all the soldering job is crap ... There is will be a lot of problem associated with ....
To fix it .... I just retried one more time to recalibrate accelero & Headless and it worked . Seems with mine, I have to recalibrate often ...
May 16, 2016, 08:13 AM
so when we will see a flight test?
Can you tell us from which website you ordered it?
Can it lift a gopro along with the allready attached camera? (if you bought the fpv version)
May 16, 2016, 01:42 PM
Seby, I saw and liked your videos.
So what do you think of this quad?
