Apr 19, 2016, 03:08 PM
Question
Which battery charger ?
I just bought a Charger 80W recently introduced to the market who also make q-Copters (I do not want to mention the name, otherwise my letter would be deleted !)
Very disapointed with it, It neither Balance charge, discharge, charge or fast charge, it charges though.
There are so many chargers floating around, I want to know if all charges in the lower price range say below 30 are the same and one should not expect accuracy from these charges.
I have started flying model aeroplanes, I do not think I will be using more than 4S battery.
I would very much like to have your advice. Thanks
Apr 19, 2016, 04:14 PM
http://www.sgvhumane.org/
cmdl's Avatar
What capacity 4s lipo and how many of them do you anticipate charging at a time? You would need: Capacity(Ah) x 16.8 x number-of-lipos-in-parallel-charge x (2 or 3 depending on which C rate you plan to charge at - you should be happy with 2) = Watts requirement of charger.
The Turnigy Reaktor is a good charger. Watt rating depends on above calculation.
Apr 19, 2016, 05:32 PM
Max 3000 3s Battries, one battery at a time.
Apr 19, 2016, 05:38 PM
cmdl's Avatar
I've found I like parallel charging more than one-at-a-time. But if that is still your choice, then all you need is a 113.4 watt charger for a 3C rate of charge.
Apr 19, 2016, 06:23 PM
Low cost entry level: Imax B6 + laptop charger style power brick
Midrange: Turnigy Reaktor 300 + modified server PSU
High end: PL6 + modified server PSU pair
Apr 20, 2016, 06:14 AM
ggcrandall1's Avatar
Specific makes and models as well as links to the equipment are mentioned here on RCG all the time. Your post will not be deleted as long as you are reporting facts.
May I suggest you read this:
http://www.tjinguytech.com/charging-how-tos
There is a wealth of information there on LiPo batteries and charging.
30 is about $43USD. For about that the HobbyKing Accucell 6 is a reasonable charger.
In the future anytime you mention a battery please include the cell count and the mAh.
Also it would help if your country is listed in your header. That makes it easier for folks to recommend sources. I am guessing your in the UK.
https://www.hobbyking.com/hobbyking/s...arehouse_.html
This one would be adequate. You will need the power supply with it.
Glen
Apr 20, 2016, 07:31 AM
Thank you very much for your help. But no body has answered my basic question. How accsurate are these above chargers. I just bought D800, 80Watt, 7A which is hopless, does not balance any cell at all. I just want a accurate charger which would do the job properly. If in the final after balance charging, there is a difference of .01 or so I can manage it but not after balancing 4.15V; 4.10V; 4.17V.
By the way I am in UK.
Apr 20, 2016, 09:39 AM
I have a couple of cheapies and they're a lot more accurate than the numbers you give. In fact I've never seen any charger that bad, if it's actually finished balancing. Oh and if what you're doing the measuring with is reasonably accurate.
Steve
Apr 20, 2016, 02:42 PM
Which Battery Charger ?
Steve
Hi Steve please share with me the charger which you have in your collection, which is most accurate among them. Thanks
Apr 20, 2016, 03:17 PM
beg,
This charger should satisfy your requirements. It a bit over your price but is in a UK store. It's 60W and is AC power so you will not need a power supply.
http://www.modelsport.co.uk/skyrc-s6...roducts/395139
Glen
Apr 21, 2016, 03:24 AM
I have an 80W Accucel-6 that is as good as anything (balance within 0.02V, usually 0.01V). And that's not just relying on the charger's display but measured with an external DMM.
But you may not find one identical these days, it's an earlier version than https://www.hobbyking.com/hobbyking/s...arehouse_.html (no HV support).
Steve
Help! Charger or battery? Which is bad? Schwemmer Multi Task F3X 9 Nov 14, 2016 07:48 PM
Question Which Battery charger? athlonoved Beginner Multirotor Drones 2 Sep 26, 2016 05:45 PM
Help! Which lead do I need to connect batteries to charger please? BlackVenom Batteries and Chargers 7 Aug 16, 2016 07:54 PM
