Futaba 4PXR - Limited Edition
This all-new surface transmitter system features a black chrome finish and is 30% faster than the 4PKS-R.
A Functional Work of Art
The all new Futaba 4PXR Limited Edition is a telemetry-enabled 4-channel powerhouse of a surface transmitter with a sleek black chrome finish. The 4PXR features a TFT color screen that's easy to read in any light condition, and is compatible with T-FHSS, S-FHSS and FASST protocols.
CLICK HERE for more info on the new Futaba 4PXR - Limited Edition
Futaba 4PXR Feature Set:
  • 30% faster and 0.5 oz (15 g) lighter than the 4PKS-R.
  • Black chrome finish.
  • 3.5" (89 mm) QVGA (Quarter Video Graphics Array) TFT (Thin Film Transistor) color LCD screen makes navigation and programming fast and simple.
  • Three grip choices (two are optional).
  • Durable, long-life wheel potentiometers.
  • Two durable, throttle trigger options with tension adjustments.
  • Large, assignable switch that can be touched by a driver's body is located on the bottom edge of the transmitter.
  • Low steering wheel position with drop-down option.
  • Steering wheel can be switched for left-handed drivers.
  • Trigger unit can be adjusted forward or backward by 7 mm.
  • Compatible with these T-FHSS, S-FHSS and FASST™ receivers: R304SB, R304SB-E, R614FS, R614FF-E, R2104GF, R204GF-E, R203GF and others as they are developed.
  • 31 telemetry sensor slots available (sensors sold separately).
  • Synthesized voice for telemetry data.
  • Multiple crawler functions — including 4WS mixing and Dual ESC mixing.
  • Internal aluminum frame.
  • 5 programmable mixes.
  • 40-model memory.
  • Steering mixer.
  • Brake mixer.
  • Gyro mixer.
  • CPS (Channel Power Switch) mixer.
  • Tilt mixer.
  • Adjustable dual-compound steering wheel can be switched around for a different feel.
  • Multi-function jog switch.
  • Grip with built-in vibration.
  • Built-in S.Bus servo/Futaba ESC/telemetry sensor programmers.
  • Mechanical ATL.
  • 32° and 34° wheel adapters.
  • Earphone jack.
  • Battery charging jack.
  • Built-in speaker.
  • Adjustable rotating antenna.
  • Compatible with 2S LiFe batteries, NiMHs, dry cells and other battery options.
  • Lasts approximately 10 hours in T-FHSS mode and approximately 6 hours in FASST mode using a LiFe battery.
  • Micro memory card slot.
  • Free user-updateable software.
  • Push-button power switch with auto-off function.
  • Clock and voltage meter.
  • Neck strap holder.
Apr 18, 2016, 12:34 PM
Right Rudder
PittSpecial's Avatar
Matt,
Very nice write-up
Please take a look at your PM inbox. I sent you a PM a few days ago.
Apr 18, 2016, 12:35 PM
Right Rudder
Matt,
Very nice write-up!
I sent you a PM a few days ago!
Pitts
Apr 19, 2016, 10:59 AM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
dayum that is expensive
Apr 19, 2016, 11:47 AM
Buggy in style
My Futaba was 700$CAD in 1991.
Sent from my ONE A2005 using Tapatalk
