FMS 1220mm Super EZ Trainer, Recommended Newcomers read 1st 12 Posts - Page 38 - RC Groups
May 14, 2017, 12:31 AM
Niceoldlady
Originally Posted by cjpace
Hi all, I'm getting my EZ ready and setting up servo throws... I can't really seem to get 15mm of aileron differential, even maxed out on the horn and clevis. Rudder and elevator I had no problem. Seems like I can get around 12mm max on the ailerons, but maybe this is not a big deal as the early part of this thread seems to indicate it is sensitive on ailerons anyway??
I fly mine with 10mm of throw both up and down on all control surfaces, flies great. Of course I don't do stunts or 3D with that but that's not why I have this plane,
May 14, 2017, 09:20 AM
Blue Skies
hifinsword's Avatar
Are you setting max throws on the AILs by moving the control rod to the inner outer-most hole on the control horn and the outer inner-most hole on the servo arm? If that is set, there are 2 other easy options. One is to get longer extensions on the servo control arms. And two is to change the "Travel" percentage on your Tx. But going over 100% can be a problem with certain stabilizers.
Don
EDIT: Thanks Ken
May 14, 2017, 09:48 AM
Ken Myers's Avatar
Maximum throw is the outer most hole on the servo arm and inner most hole on control horn.
May 14, 2017, 10:56 AM
Description:
This is the setup (similar on the other aileron, never mind the out-of-place keeper). I think the radio setup is ok too... when configuring endpoints the unattached servos ran out of travel well before the max/min pulse width of the Tx. Travel is symmetrical and both servos move the same amount (I'm driving them both with the standard Y-harness.
May 14, 2017, 01:50 PM
Blue Skies
hifinsword's Avatar
Attachment 10038085
That's the right mechanical setup for max throws. If the "TRAVEL" menu on your Tx is set to 100%, the only other limit is the D/R setting. You should be able to go to about 125% for each direction, UP/DOWN on D/Rs on most Txs, but I think that's dependent on the Tx. Of course you can go up to 150% on the "TRAVEL" setup and then back off the percentage on the D/R menu so it doesn't overdrive the servos. That's the usual way to find & set max travel for the servos. But I don't recommend over 100% on the "TRAVEL" menu if using some stabs.
The "TRAVEL" at 150% and D/Rs at 125% should be all it can go, and probably more than the servos can go. But that's the only other setting I can think of to maximize the throws. If the servos are hitting their limits at less than the max, that's all it can do. I don't understand how your servos could be any different than the rest of us unless they are not the same as the stock ones the rest of us received.
Don
P.S. A mix, differential or a flapperons setup could limit the travel if any are present.
May 15, 2017, 12:54 AM
Grup's Avatar
You could make a longer servo arm...
Another way to get more authority would be to extend the chord of the aileron. Basically, turn SuperEZ into SuperEZ3D!
May 15, 2017, 05:39 AM
Thanks for the different comments on the aileron setup.... I think I will just go ahead and see how it flies first before making other changes, I just wanted to make sure I wasn't missing something simple during setup (first time doing this)
May 17, 2017, 04:04 PM
Ken Myers's Avatar
Originally Posted by Ken Myers
The 18 gauge is the smaller wire. Remember that as the gauge number increases, its diameter decreases.
I was on the FMS site and the new, upgraded version, V2, has the same part number for the ESC listed as V1.
Just an observation, as I was surprised to see the smaller diameter wire on the power leads of the ESC of my student's plane.
I was wrong in guesstimating the power lead gauge on the current stock ESC. I had one in my hands today while diagnosing an ESC/Motor issue for one of my student pilot's planes. The wire actually says 20AWG. I knew it was small, but that is just unbelievable.
The problem turned out to be a bad ESC, which Motion RC is said to be replacing.
I was quite surprised that there were no comments from you folks about the small gauge power wire leads after my first post. To me, 20AWG seems just too small for power leads on an ESC rated at 20A.
May 20, 2017, 12:23 AM
Going back to balsa
I got a nice relaxing flight in on my stock EZ today, and after recharging the battery found that I had only used one amp hour for a fifteen minute flight.
Anyway after landing on the beach here on the Tomales bay discovered that I had my camera in a pocket. So here is a respectable photo of my flying site.
May 30, 2017, 06:06 AM
Ken Myers's Avatar
Motion RC did not replace the faulty ESC from my student pilot's plane. I gave my student pilot an ESC that I had on hand to get him back in the air.
Jun 04, 2017, 01:15 PM
Blue Skies
hifinsword's Avatar
Repairs done; test flight complete
I got my EZ repaired but I will be replacing the fuselage. It's already delivered but I'm in no hurry to changeover. I fly a few days ago and was happy with the performance. I think the extra foam and glue has made it nose-heavy. But I've compensated and it flies well enough. It has a new prop adapter and prop.
Don
2017.6.2 FMS Super EZ with Hobby Eagle A3 Super 2 stabilizer (5 min 6 sec)
Jun 10, 2017, 06:53 AM
Mine flies a little nose heavy with 149gram 1800s all the way aft. I do have a little tape on the landing gear, some Ca in two cracks in the fuse under wing. Other than that she's still a great relaxing, fun model to fly wind or not. Just hit 102nd flights this morning.
Jun 10, 2017, 08:24 AM
Grup's Avatar
Mine after repairs seems to be jinxed. I noticed just after repair that the nose was bent over to the right, increasing the right thrust. So I adjusted the thrust to reduce, to what I thought was normal thrust (approx 3 degrees). Still too much right thrust.
So, adjusted it back some more; maybe 1.5 degrees. Still too much; required full left trim to track straight.
So, adjusted it back to what looks like 0 degrees. Still too much, requires 75% of possible left trim.
I did a test where I went up high, got some speed, and cut motor. It tracked straight, even with 75% of left trim, with motor off. I believe this means that it's not motor thrust line but something with vertical stabilizer, wing, etc.
I'll probably just fly it like it is until it gets a bit more beat up, retire it and get a new one or suitable replacement. I sure did like it...
Regards
Jun 10, 2017, 02:13 PM
Just started flying mine with mini dvr cammera mounted on the wing. Can't seem to figure out how to save and upload the videos.
Jun 11, 2017, 05:02 AM
Blue Skies
hifinsword's Avatar
I dug out the stock ESC I had replaced with an E-Flite 40A ESC taken from my E-Flite Spitfire. The wires show 14AWG gauge wires rated for 200 degrees Centigrade on them. It looks like they ran out of 14AWG wire at the factory the day yours was made and thought 20AWG looked OK. MotionRC or someone owes you that new ESC.
Don
