Aug 16, 2004, 03:53 PM
Ib Jensen's Avatar
Servo Sizing
Can anyone point me to a link that will help me determine the torque requirements of a servo for a given control surface size and expected speed range? I am sure that I saw something along those lines a few years ago but I have been unable to locate anything via Google.
Ib
Aug 16, 2004, 05:27 PM
repost:
Quick Servo Moment Prediction
Xfoil is a reliable means for predicting a flap hinge moment.
But it can be closely approximated by the following formula:
M_hinge = K * Lift * flap_chord * (flap_area/wing_area) / CL
Multiplying by the servo/flap "gear ratio" then gives the servo torque:
M_servo = M_hinge * (servo_arm/flap_horn_arm)
The constant K depends on the airfoil camber and the flap deflection.
Conservative upper-limit values are:
K = 0.30 40 deg flap (landing)
K = 0.25 15 deg flap (launch)
K = 0.15 5 deg flap (snap-flap turn)
Example 1: Aegea 130" glider on strong winch or two-man tow launch.
K = 0.25
CL = 1.2
Lift = 150 lb
flap_chord = 2.4 in
flap_area/wing_area = 0.067
servo_arm/horn_arm = 0.75
M_hinge = 5.0 in-lb = 80 in-oz
M_servo = 60 in-oz
In this case, the flap is deployed before launch.
So the servo merely needs to hold this torque
without breaking and without too much compliance.
Example 2: 3m slope racer in turn.
K = 0.15
CL = 1.0
Lift = 90 lb (6 lb weight at 15 g's)
flap_chord = 2.0 in
flap_area/wing_area = 0.060
M_hinge = 1.6 in-lb = 26 in-oz
M_servo = 19 in-oz
In this case, the flap is deployed under load.
So the max servo torque must exceed this 19 in-oz
torque by an adequate margin.
Aug 16, 2004, 06:19 PM
Ib Jensen's Avatar
Thanks Mark,
I am trying to decide if I want to add flaps to 4M scale ship and didnít know what I would need to install. The formula should give me a good idea since the flaps would be longer than any I have done in the past.
Ib
Aug 16, 2004, 09:34 PM
seaotter's Avatar
hi ib,
although dr. drela more than adequately answered your question, here's a quicky, plug-in servo calculator.
http://www.csd.net/~cgadd/eflight/calcs_servo.htm
Aug 17, 2004, 02:14 PM
nuevo's Avatar
I used to use a spreadsheet published by Craig Tenney several years ago. A copy of it is available on this page:
http://www.rrcc.org/downloads.htm labeled RC Calculator
I do not know if the results from this spreadsheet correlate with Mark's equations.
Aug 17, 2004, 05:34 PM
Ib Jensen's Avatar
Thanks for the links.
This will help confirm my guestamate.
Would you use Xfoil to calculate the torque requirements for pitherons?
Ib
servo sizing - how? flieslikeabeagle Power Systems 12 Jul 11, 2005 11:32 PM
Servo Sizing, figuring out how much torque is needed? jh2rc97 Electric Plane Talk 3 Jun 18, 2005 08:58 AM
Servo sizing raabid Electric Ducted Fan Jet Talk 0 May 25, 2004 08:59 AM
