OpenTX LED programming problem - RC Groups
Apr 11, 2016, 07:22 PM
I have a Taranis X9D and am attempting setup LED logic but am running into roadblocks.
I have LED strips correctly turning on with SG switch down. With SG up (LEDs off) and F/S switch on (SF down) I have the lights programmed to flash on/off (working correctly with LEDs off - SG up).
My problem is with SG down (LEDs on) and then SF down (F/S on) the lights remain solid. I want the lights to flash with F/S on (SF down) regardless of other criteria.
My setup in Open TX:
Mixes:
CH 8 SG Weight (+100%) Switch (SG down) **LED on**
R L14 Weight (+100%) Switch (L14) **LED with F/S on**
Logical Switches:
L13 Sticky SFdown SFup
L14 Timer 0.1 0.1 L13
I thought the "replace" on the 2nd line of Ch8 would replace/override line 1. I've tried swapping line 1 and 2 but no luck. Can anyone help?
