HOBBY LAND (Doha, Qatar)
Apr 11, 2016, 04:03 AM
New Product
46 inch RC boat for sale QAR 1500
THIS IS A VERY GOOD DEAL, i have invested more than 1,300.00 USD,used only one time for testing,all parts are new. SALE PRICE: QAR 1500 please see below complete description: Reply if interested.
Hull:
Made out of plywood, enforced with epoxy. I have ordered the kit from zippkitsdotcom, easy Vee mono hull. RRP USD 59.00
Manufacturer description:
Handles rough water with no trouble.
The specs are as follows:
Length- 46 inches
Beam- 13 inches
Weight- 12-14 pounds
IMPBA Legal
NAMBA Legal
Hardware:
From the same manufacturer RRP USD 365.00 with the following description:
Ultimate Hardware Combo Includes:
90 Degree 1 inch offset stainless header
No Leak exhaust flange
Super Tuned Quiet Pipe
Tuned pipe mount
Gas engine mount
Zenoah coil relocator
Super collet
Throttle bellcrank set
1/4x24 Flex shaft
5/16x36 brass shaft tube
Tygon fuel line
8 Feet 5/32 silicone water line
2-56 Pushrod
4-40 Pushrod
2-56 Nylon clevis
4-40 HD ball link
4-40 Solder clevis
EZ Connector
Kwik Switch Mount
470 Prop
2 Water outlets
Dual pickup 6 inch rudder
2 transom turn fins
Trim tabs
1/4 inch adjustable stinger drive
Pushrod seals
Drive dog
Prop nut
Engine:26cc Marine RRP USD 500.00 with following description:
This Pro Mod Engine produces excellent throttle response, Broad power curve, Responsive idle and Longevity.
Transmitter- receiver RRP USD 50.00
Flysky FS-GT3B 2.4G 3CH Transmitter & Receiver With Fail-Safe For RC car boat
Introductions:
A responsive transmitter can always bring you exciting and free flight. If your former helicopter transmitter has been out of order now and you need a reliable spare part to replace it, this FS-GT3B 2.4GHz 3CH Remote Control Transmitter must be highly recommended. It features quick response, easy operation and control. Also, the compact and lightweight design makes it easier for you to carry it when you are going outside. A nice spare part for all helicopter lovers! Get one as soon as possible!
Features:
1. 2.4G and 3CH transmitter with interface for convenient charging
2. With sensitive and stable performance, it is practical and durable
3. Small size, lightweight, easy to carry
4. With it, you can control the helicopter easily
5. It features quick response and easy operation
6. A basic and necessary spare part for your FS RC helicopter
Specifications:
1. Model: FS-GT3B
2. Material: ABS
3. Color: Black
4. Number of Channels: 3Channels
5. Suitable Models: Cars/Boats
6. Frequency Range: 2.4GHz
7. System Type: AFHDS
8. Code Type: GFSK
9. Senditivity: 1024
10. ST Range: 90 Degrees
11. Charger Port: Yes
12. Power: 12V DC (8 x 1.5V AA)
13. Dimensions: (5.91 x 4.53 x 7.48)" / (15 x 11.5 x 19)cm (L x W x H)
14. Weight: 21.44 oz / 608 g
Cannopy: Rockstar RRP USD 100.00
Includes other hardware as well like: Fuel system, servos, batteries (two), battery charger, other small hardware, all will be send along with the boat.​​​​​​​​
