This thread is privately moderated by santanig5, who may elect to delete unwanted replies.
Apr 09, 2016, 08:20 PM
Ghost Rider the pattern's full
santanig5's Avatar
Build Log
HK Hummer EPP 3D
The Hummer EPP 3D is a high performance profile foamy.
The Hummer's ultra-durable EPP construction and carbon fiber reinforcement means that it can really take a beating. This is ideal for pilots looking to practice 3D manuevers without the fear of destroying an expensive balsa model.
The Hummer EPP arrives in kit form, so you will need to add your own electronics. The build is straight forward. A detailed assembly manual w/photos is included but is lacking, found some good vids on You Tube.
Simply add your own 1000KV brushless motor, 1047 slow fly prop, 20A ESC, 4 x 9g servos, 4ch radio system, 3S lipoly battery and your ready to fly!
Specs:
Wingspan: 1000mm
Length: 950mm
Flying Weight: 450~500g
Requires:
4ch transmitter/receiver
2212 / 2213 1000KV brushless motor
20A brushless ESC
4 x 9g servos
1047 slow fly propeller
3S 11.1V 850~1300mAh lipoly battery
