Apr 08, 2016, 05:00 PM
1/8th Scale 2.4Ghz Exceed RC MaxStone 4WD Powerful Electric RC Rock Crawler
Exceed RC Maxstone Rock Crawlers 1/8th vs 1/10th vs 1/18th First Look (6 min 57 sec)
1/8th MaxStone Four Wheel Steering Conversion (3 min 47 sec)
MaxStone 1/8 RC Rock Crawler 4 Wheel-Drive, Power Steering, Suspension (Laguna Beach Hills) (2 min 25 sec)
Additional photos can be found here
The 2.4Ghz RTR Exceed RC MaxStone was designed from the ground up, and every detail was thought through to provide a competition level base kit to work with. Previously the only way to build a competition capable rock crawler was to buy bits and pieces of several different kits here and there. This long and sometimes frustrating process could take as long as several months just to get the right parts together before you could even start the build. Now you can get a factory built rolling chassis,?and able to hit the rocks with your competition ready in no time.
The Rock Crawler embodies good features from real rock crawlers. Multi-link suspension and axles provides all 4 wheels through A center-mounted 3-gear transmission, providing tremendous grip and torque at all times and overcome any obstacle that it may meet with.
Features:
Full ball bearing throughout whole vehicle
Multi-link suspension allows for smooth crawling
Four wheel driving provides tremendous grip for wheels
Aluminum sold "X"-type side guard
"Truck/Hammer/Wecker" style body
Alloy lower suspension link bars with captured ends
3-Gear center-mounted transmission
Solid axle mount provides protection for front/rear shaft
High precision ESC w/ reverse function
High precision 2 channel receiver
Designed from the get-go as a?rock crawling machine that goes anywhere.
Super long nitride coated shocks offer a wider range of articulation.
The 2.4Ghz RTR Exceed RC MaxStone transmission was designed to place the weight of the motor as low as possible to maintain a low CG (Center of Gravity).
The 2.4Ghz RTR Exceed RC MaxStone chassis is lightweight and stiff.
Advanced battery mounting design.
Axle -Mounted steering servo.
Dual High-torque 540 motors.
Advanced tire pattern provides best grip and balance.
High performance electronic speed controller.
Advanced monster stocks design provides the best support.
Unique Aluminum Alloy twin vertical plate chassis design
Revolutionary multi-link crawler suspension design
Heavy duty special harden metal ring and pinion gears, axles and axle shafts
Advanced aluminum alloy suspension links
Advanced locked differentials four wheel drive design
High performance motor design
High performance heavy duty rock crawling servo
High performance racing level 7.2v 2000mah ni-mh battery.
Specification:
Length: 655mm (25.79 inch)
Width: 375mm (14.76 inch)
Height: 320mm (12.60 inch)
Wheelbase: 460mm (18.11 inch)
Wheel Width: 82mm
Wheel Diameter: 182mm
Steering Angle: 40-50 degree
Maximum Torque Angle: 90 degree
Engine: Dual RC540 motor
Weight 5150g
Battery: 7.2V 2000mAH Ni-MH
Package Include:
MaxStone RC Rock Crawler (100% assembled)
7.2V 2000mAh Ni-MH Rechargeable Battery
Wall Battery Charger
2.4Ghz Pistol Grip Radio Remote Controller Transmitter
Instruction Manual
Oct 31, 2017, 01:47 AM
mkpatrick
Will the ESC on this crawler handling a 2S lipo pack?
M
Feb 09, 2018, 10:36 AM
mkpatrick
Servo mount for 4 wheel steering
Anyone know where I can get a servo mount for this? They always seem sold out.
How about a reasonable alternative that will fit? I want to setup 4 wheel steering.
