This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Apr 08, 2016, 11:57 AM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Mini-HowTo
DJI Phantom 4 & Update Information -Known Issues - Troubleshooting -
DJI Phantom 4 Firmware Update - Troubleshooting and common Issue Information Updated 08/12/2016
Please note this info is for the Phantom 4 only and not the Phantom 4 Pro, see the second post for info on the Pro
The Phantom 4 is available from DJI
http://click.dji.com/ewNB7_KlW2SdbyRy?pm=link&as=0001
Please Note: As with all my own blog post all links may be affiliate links and i will receive a small commission on any purchase bought through them , if you wish to support me then thank you however it is not expected .
Please note it is advised you do not update to the latest FW a minute - See Below Under Known Issues
Latest FW version for the Phantom 4
Craft v02.00.0106
Remote Controller v1.9.20
DJI Go & DJI Go 4
DJI has branched off its Go app into 2 versions, from this point forwards you should use the correct app for your model, while the later versions of the Go App V3.1 do support the Mavic Pro and P4 its advised to move over to Go 4.0 as per below.
Use DJI Go V3x for the following products
Phantom 3 Series
M100/M600/LB2
Use DJI Go 4x for the following products
Phantom 4 Series including the P4 Pro
Mavic Pro
Inspire 2
KNOWN ISSUES
FW V02.00.0106 POOR HOLD AND FLIGHT BEHAVIOUR
A number of users have reported poor flight performance and flight behaviour from this updates, this does not affect all users but its clear some are getting this after the update.
FIX: There is currently no fix for this as downgrade fw option was removed officially in the latest firmware.
Currently DJI had not release a fix for this issue.
FPV BLOCKING AND POOR FEED AFTER RC FIRMWARE V1.8
A number of users have reported very bad live feed link after updating the RC firmware to V1.8, this appears to affect users with the HDMI board fitted more than others but its pretty random.
FIX: Currently the only solution is to downgrade the RC back to V1.6 firmware and this should resolve your issues, You may also need to delete DJI Go, Reboot the smart device then download DJI Go again.
FIRMWARE UPDATE PROCESS
Important- If you are on fw v1.0.288 or earlier you must update the craft before updating the controller otherwise you will loose connection, v1.1.301 contains a Lightbridge security update and if you update the controller first you will loose the link to the craft, see Troubleshooting below for more info.
V1.1.301 onwards is only compatible with V1.6 controller fw onwards, both must be updated to allow connection.
Updating the Craft via DJI Assistant 2 App PC/MAC
There are 2 ways to update the Phantom 4 craft, the first is via the Assistant 2 PC and Mac Application, this can be downloaded form the DJI website under the downloads section, the second method is via the DJI Go App, this video shows both as well as how to update the Remote controller
Phantom 4 Tutorials– How to upgrade the firmware on your Phantom 4 (4 min 40 sec)
Updating Craft and Controller via DJI GO
First make sure you have the latest version of DJI go on your device
Turn on Craft and controller and you will be notified of an update is available
Click on the "Firmware Requires Upgrade" and it will show you the RC Requires Updating at the top, do nothing at this point
Wait a few more seconds and it will pop up with the craft requires an update as well
Click the craft update and it will tell you to return to the main screen, you will see the following
Click update now and download the update
If you find the download keeps pausing make sure your connected via 5.8ghz wifi, if thats not available you may need to turn off your craft and controller at this point as the Lightbridge connection may be interfering with your wifi connection preventing the download.
Once downloaded you will need to connect the Tablet to the craft via the USB cable DJI provided, turn on both the craft and controller, after a short time it will allow you to begin the update
Note this update was silent for me with a craft reboot at 96%, the gimbal may twitch as the update proceeds, all normal.
Once complete turn everything off and then turn on just the controller
Now you will get the RC requires update message on its own this time, Click Download Firmware then update.
Once downloaded and updated you should see RC Upgrade Complete, This part of the rc update again was completely silent for me.
Reboot everything, i got the 'Cannot Take Off' error, it then again asked to update the controller, this time the controller updated but with the normal update tones.
Once complete
Rebooted and everything was up to date and working.
Controller FW Downgrade Process
If you update the controller before updating the craft but can't update the via Assistant 2 for some reason you can downgrade the RC back to V1.580 as follows
Connect the controller to the Tablet and turn on
On the DJI Go home screen press and hold the Academy (little hat) icon in the top RH corner, you will need to hold this for at least 10 seconds and when you release you should get the below screen
This will allow you to select the last FW version and downgrade the controller allowing you to reconnect.
Troubleshooting Updates
No Signal- Flashing Yellow Lights on Craft
If you updated the controller to V1.6 onwards before updating the craft you will no longer be able to connect due to a changes in the encryption between them , you have two options
1: Update the craft to at least v1.1.301 via the DJI Assistant 2 App on PC or Mac then you will be able to reconnect
2: downgrade the RC back to V1.5, See below instirctions on how to downgrade, once downgraded you can update again but update the craft before the controller
If your unable to connect after the update try rebooting the tablet/Phone, if that does not work delete the Go app, reboot the Tablet/Phone and download DJI Go again.
Issue: DJI Assistant 2 App not showing FW screen
Unable to perform vision system calibration or update fw via Assistant 2 app.
Resolution: Ongoing issues for some but try the following
Windows - Make sure you are running DJI Assistant 2 with Administration rights, Make sure drivers are correctly installed
Mac - Make driver packager is installed.
Hopefully will be resolved with update in near future.
Issue: No Update Prompt for Controller
Currently some people are having issues getting the DJI Go App to prompt them to update the latest firmware V1.6. it seems there may be an ongoing issues with DJI servers and it also wont show the current version either and just shows "Unknown".
Resolution: Try deleting the Go App, rebooting the smart device and then downloading the app again, make sure the device on online by opening your browser and going to a known working website, connect to controller then turn on and open DJI Go and go to camera screen, If prompt does not come leave on sitting there for 15m and see if appears, if not, try rebooting the device a few times.
There have been a number of people unable to resolve this and as posted it seems there may be a server issue at DJI, will Update when resolved.
GENERAL ISSUES and TROUBLESHOOTING
Object Avoidance System Errors or Poor Performance
If your having poor altitude hold or are getting avoidance system errors perform a calibration of the avoidance system cameras as follows
Phantom 4 Tutorials - Calibrating the Vision Positioning System (3 min 22 sec)
Locate Update Log File
To check if your update has been successful or provide DJI with further details
Phantom 4 Tutorials – Finding an Upgrade LOG File (1 min 52 sec)
Link Phantom 4 RC
To link the Radio Controler to the craft see as follows, note both the P3 Gl300 Series and Inspire 1 GL653 remotes will work with the Phantom.
Phantom 4 Tutorials - How to Link the Phantom 4 with Its Remote Controller (1 min 30 sec)
Installing HDMI Board on Phantom 4 RC
This is the same identical process as on the Phantom 3 Advance and Pro
Phantom 3 Tutorials- How to install HDMI Output Module on Phantom 3 Remote Controller (4 min 29 sec)
Poor Range and Signal
Make sure you are correctly orientating the antennas when flying
DJI Tutorials - Remote Controller Antenna Best Practices (3 min 22 sec)
Poor Live Feed, Brake Up, Live Feed Dropouts
If your getting No signal, Poor live feed, Dropouts and overall poor Lightbridge connection issues try the following
Resolution:
Replace SD Card with another, A bad SD card can cause Live feed problems
Try custom channel setting and set to a clear channel and set to 4mbps
Try installing the channel mod and using custom channel on a clear channel out of the normal band
Blurry Live Feed and Recorded Video - RESOLVED
Affected both live feed and SD card recorded video on all resolutions, Bug was introduces in v1.1.410.
Resolution:
Install FW v1.1.411
DJI GO 2.8.2 IOS Picture Breakup on P4 - RESOLVED
After release is was quickly spotted that people were getting live feed problems at very short range, line, blocking, also its noted that the blue channel bar in the HD screen does not appear to be showing.
Resolution:
DJI Go 2.8.3
Issue: Height drop when coming to a stop in GPS Modes- RESOLVED
When coming off the sticks in GPS mode and Sport mode some people are experiencing the craft loose height buy up to 2-3m, I have also noted just before it comes to a stop the craft acutely increases hight then begins to drop
Resolution:
Firmware v1.2.503 should fully resolve this issue.
Issue: Battery cracking around light guide-UPDATED
The battery latch spring presses hard against the inside wall of the battery cover and it seem some have hound cracks appearing in the battery casing around the light guide
Resolution: I appears there are 2 batteries in circulation, the original with the lightwave that had a even green glow to the lights, a second version where the LED's are much brighter and you can see the individual diodes thought the light guide when on, it appears that the cracks only are happening gin the first battery mentioned.
Either way contact DJI support to arrange replacement/repair of battery.
UPDATE: reports of this have basically fallen off to nothing, It appears it was something with initial batches.
Issue:Gimbal Squeak- RESOLVED
Some reports of the gimbal give off a chirp when fired up
Resolution: FW v1.1.410 should mostly remove this , Almost all reports of this happened after performing fw update and it went away after that, one or two reports of it happening longer but its not a gimbal fault, likely the motors letting of a little noise as they power up.
No reason to exchange product for this.
May 14, 2016, 12:03 PM
Please Note this thread is not regularly monitored, if you have any issues or need help please post them in the Official DJI Phantom 4 Owners thread https://www.rcgroups.com/forums/show....php?t=2608687
