Thread Tools |
This thread is privately moderated by burkefj, who may elect to delete unwanted replies. |
F-100 Super Sabre
Here is another one I did a long time ago and wanted to update the shape and plans. I always wanted a sig kobra which had a sort of similar shape/color scheme and I've always liked the F-100 in thunderbird scheme, I decided not to paint it silver and just leave it white to save a bit of weight. I did the vinyl freehand and it's not perfect, but came out looking ok. Added the panel lines and some titanium/silver for the exhaust/afterburner area since this typically shows through on the F-100 even when painted...
Here are some build photos as I went along. Maiden this morning was really nice, just a few clicks of up and a few of left aileron and it was good to go. I'm at about 26% MAC for CG and it is very docile. Very slow high alpha and good loops and rolls. 4:40 flight time with an 800 3s pack, and grayson microjet V-3 and tbird 18 esc and apc 6x4E prop. 16 ounces auw rtf. Plans as usual are at: www.dynasoarrocketry.com go the plans pulldown and select parkjet plans Note that the wing is a c model with a straight trailing edge, if you want a d model you can simply cut the Te perpendicular from the inboard aileron tip to the fuse and enlarge the fuse slot to match. You may be able to move the cg back slightly. Frank ImagesView all Images in thread |
Here's some flight video from today.
Frank |
Thread Tools | |
Similar Threads | |||||
Discussion | Scrachbuilt F 100 super sabre | candane | Scratchbuilt EDFs | 32 | Jan 30, 2018 10:46 AM |
Build Log | RBC Kits F-100 Super Sabre 70mm EDF | gionir | Scratchbuilt EDFs | 54 | Jan 08, 2018 03:21 PM |
Build Log | F-100 Super Sabre 50MM fan from Comet Plans | addictedtoplanes | Scratchbuilt EDFs | 10 | Nov 10, 2016 09:19 AM |
Found | Flyfly f-100 Super Sabre | sirlordwhitman | Aircraft - Electric - Jets (FS/W) | 0 | Sep 12, 2016 08:27 AM |
Wanted | F 100 Super Sabre | DRHagen | Aircraft - General - Miscellaneous (FS/W) | 2 | Oct 23, 2015 03:07 PM |
