Eachine Falcon 180 Mini FPV Racer From Eachine, Quanum Outlaw 180 Killer? - Page 58 - RC Groups
Mar 15, 2017, 03:28 AM
Reportbuttonsnitch
Originally Posted by Blastsniper
Anyone tried opening these motors up? The grub screw is tiny.
Not these but the similar constucted ER250 ones to replace the bearings - leave the grub screw in place and remove the clip at bottom. Working with these clips should be done in a plastic bag, they tend to jump away and you never find them again.
Mar 15, 2017, 09:49 AM
Originally Posted by KopterGeza
Never mind, Eachine VTXes never were top quality. You weren't the only who experienced the magic smoke from the Falcon's VTX.
BTW i just bought an FT48X VTX - it is quite small and it has selectable transmit power from 0.25mW to 600mW. It has an 5V output, so it can power the Falcon's cam.
im rocking the eachine TX526 with switchable power as well, i think i just need better antennas. using those orange/white mushroom antennas from banggood.. they are cheap but not very good. Should get those aomways 4 clover leaved antennas.
Thanks Dropax for the tip, i would like to try to fix the replaced motors, one makes a funny sound and the other one is a bit rough. So would like to give them a proper maintenance, and maybe i can use them as spares again!
Mar 17, 2017, 07:28 AM
I ended up putting an Eachine VTX03, that has just the whip antenna. Works well enough where I fly it, saved a little weight on an already super heavy quad. Since it's so tiny it was super easy to wedge in the bottom section with the whip coming out the back.
Mar 20, 2017, 08:59 AM
How have people mounted the pdb inside? Do you need to drill extra holes for the fc?
Or do you need different standoffs?
I guess you can suspend it with washers so it fits the fc screws.
Mar 20, 2017, 09:18 PM
My head in the clouds!
Cyclone Steve's Avatar
just picked up this little quad and my buddy let me borrow his teleporter v5 headset. I'm a noob to fpv but I'm pretty sure I need to change the frequency on the drone itself to get it to pair with the headset. How on earth do you change through the channels on the drone? I see them I just dont know how to change them...
Mar 22, 2017, 01:13 PM
The teleporter should be able to change freq also, not sure if that's easier. The button for changing them on the quad might be obstructed depending on how they mounted it, you might need to take off the bottom plate to remove it and see. Not sure, I got the ARF version without camera/VTX.
Mar 22, 2017, 02:12 PM
I will try and find it. I'm a complete noob to FPV and flew the quad a few times with the antenna off. I just read somewhere that this could fry the tx.. great. Quad flies nice though!
Mar 22, 2017, 03:08 PM
There is a button on the vtx. Short press changes channel, long press changes freq range.
Mar 23, 2017, 11:03 PM
So I found the exact tx on banggood site and it shows the button but there is no button that I can find on the one that came with the quad.. But, I just got a set of quanum cyclops goggles and it picked up the channel so I'm all set! And the good news is my tx is not fried!
Mar 25, 2017, 02:01 PM
The button is inferior, and breaks off easily. You need to short the button to change channels otherwise, or click it from the top.
I myself got the quanum v2 pro diy goggles, and i'm impressed. Good isolation.
Only problem now it seems my audio won't record anymore, gotta find out why.
Think im getting the hang of it.
modded falcon 180 (3 min 55 sec)
Mar 27, 2017, 01:45 AM
Sky007FR's Avatar
Hi guys,
A little video to show that this quad can be used for racing !
Fast and Furious FPV Racing @ Miribel-Jonage 3/3 (180 size) (2 min 15 sec)
Enjoy !
PS : same track, smaller quads :
Qattrovolante QCarbon85 : https://youtu.be/lfp1gCCbgQw?list=PL...pUKUkicuxPH7Gj
Eachine Racer 130 : https://youtu.be/Yi7WdYE0lIg?list=PL...pUKUkicuxPH7Gj
Mar 30, 2017, 10:49 AM
so i just put the PDB above the frame, but in my fumbling around i accidentally destroyed one of my ESCs (don't ask), anyway, i got a new set of 4 Flycolor Raptors, but they appear to be just a gnat hair longer and won't fit between the motors and the PDB along the arms (well they will fit, but not if i want to use wires to connect them < grin >), i have thought and thought about what to do, and my solution is to mount them under the arms, i will be putting 3M foam feet down under the motors so i will not be landing directly on the ESCs but i am somewhat uncomfortable them being down there. Any other ideas? .. i guess the fact that i am so new, actually landing face up will not be happening any time soon should help.
Apr 03, 2017, 07:19 AM
Hello everyone I just bought this little quad with Naze32 FC, and I have a problem.
The props are mounted in the correct spots and the motors are spinning in the right direction, but the quadcopter does not lift!
It seems like it doesn't have enough power to fly. I also tried to calibrate the ESCs on Cleanflight but nothing has changed.
I really hope that someone can help me with this, if you want I can post a video of it.
Thanks in advance.
Apr 03, 2017, 03:15 PM
Thanks in advance.
A dude had a similar issue - his battery was dead.
Apr 05, 2017, 11:51 PM
Thanks in advance.
What type of battery 3S or 4S? You sure it's good? Also, any chance the props are upside down? They may look correct in the direction they are spinning, but if they are upside down they won't make much power (especially the stock props).
