Apr 13, 2016, 05:18 AM
I admit the guns are a little on the large side, but they are easier to glue, but they are on the right side, see toms post above. I had it out again on the weekend and I love it. I'm thinking bay be it needs a little more nose weight or some up thrust. then it comes in to land it hangs in the air with a little head wind. it has a little down elevator in it ATM, no real trim change as fuel goes down
Apr 13, 2016, 02:53 PM
KK4NZS / RP sUAS
Nelapaty's Avatar
I hope they will carry the stuka in the US Stores.. I wanted to get a Blackhorse models stuka and for some reason they discontinued the model.
Apr 14, 2016, 01:17 AM
seagull, phoenix and blackhorse are all related. I guess they share the planes and swap who sells it for X period of time. and do their own mods.
Apr 14, 2016, 02:12 AM
Terminater's Avatar
double post
Apr 14, 2016, 02:18 AM
Terminater's Avatar
I meant the light green cover is on the dark green side etc
also give the model a coat of matt clear, makes it look better,
and I used the mg15 gun 1/7 scale from
http://rosaminiatures.squarespace.co...rman-mg-15-792
Apr 26, 2016, 06:05 PM
KK4NZS / RP sUAS
Nelapaty's Avatar
Yippee..
http://www3.towerhobbies.com/cgi-bin...&I=LXFXUX&P=ML
Apr 26, 2016, 07:19 PM
Tower Hobbies is going to carry them in the US. You can place one on back order now, they are due in late May. I already placed mine. There is a thread that started as the Seagull ARF that has some info on the Phoenix ARF here https://www.rcgroups.com/forums/show....php?t=2527891 It's good you started a thread just for this kit.
Apr 27, 2016, 06:37 AM
KK4NZS / RP sUAS
Nelapaty's Avatar
Apr 27, 2016, 05:32 PM
Terminater's Avatar
I have the Blackhorse one and its a fantastic flyer running a G110 295kv on 8s 4000 (2x4) and 17x10 apc prop most of the time it only needs half throttle ..
I have setup Bomb drop and mrrcsound with 2 speakers in cowl... only wish is that they used the orginal tailwheel version and not the silly one now..
Flys like a big trainer but will bite u if u go too slow... ailerons aren't that effective so coupled with rudder...
PIcutures of the plane with Matt Clear on it.
the gun is a 3D 1/7 printed one from
Apr 27, 2016, 06:50 PM
I had the BH version also, sold it , wish I didn't. I agree about the tail wheel, wish it was the original.
Apr 28, 2016, 07:02 AM
KK4NZS / RP sUAS
Nelapaty's Avatar
Now is there any way to replace the tail wheel to something thats close to Blackhorse design.
Terminator great job on the bird. It looks Fantastic
Apr 28, 2016, 06:10 PM
Terminater's Avatar
I have been looking at redoing the tailwheel and found this on another forum (rcuniverse Jimmy Bananas)
He used it on a ESM stuka which is around the same size..
also helps that Phoenix / BH put the orginal tailwheel plastic cover still in the box
parts where -
Dubro Semi-Scale 60-120 tailwheel System
Dubro Nose Gear block, and a Dubro 1-1/4" streering arm
so i'll get around to changing it someday ...
Apr 28, 2016, 07:29 PM
Thanks for posting that. I already have the parts, just need the plane.
Apr 28, 2016, 07:34 PM
KK4NZS / RP sUAS
Nelapaty's Avatar
I have a e flite power 90 some where. I can run that on 8s with a 16x10 prop 75hv castle esc should do the trick. now i just have to get my hands on the bird.
Terminater what servos did you use for flaps?
Apr 28, 2016, 07:36 PM
Terminater's Avatar
I used Hs-422BB servos for the flaps
Hs-485HB for Rud / Elev and Air..
and a small Hs-85BB for bomb.
