This thread is privately moderated by kevinlau, who may elect to delete unwanted replies.
Mar 30, 2016, 08:56 PM
New Product
DOMAN RC new Magnetic Induction 360degree servo
DOMAN RC hobby recently release a series of Magnetic Induction servos,The Special Characters:
1,It is a non-contact and wear-free magnetic encoder,so it will be with especially long life,the servo life will not be suject to the potentiometer's life;
2,It is a non-contact and wear-free magnetic encoder,so the precision will not go down with the time used,this is what the traditional potentiometer unmatched;
3,non-contact and wear-free magnetic encoder goes with high linearity, high accuracy, high reliability,this make the position feedback smoothly,so if it used on the platform,it will be stepless, this completely solve the problem of multistep by traditional potentiometer;
4,Because there is no block in the gear and the potentiometer,so it can rotate 360degree,and if the output shaft runs beyond the limit,this could also avoid and reduced damage to the potentiometer and gear set;
5,magnetic encoder could go to any point of 360degree,which break through the angle limit of traditional potentiometer,this makes your product running 360degree freely and no dead angle;
All of the coreless servos could upgrade to Magnetic Induction servo,and also could do OEM servos,
one of the servo specification as bellow:
Item No. DM-CLS205TD
Operating Voltage: 6V~7.4V
Speed: 0.13 sec/60deg (6.0v) 0.11sec/60deg (7.4v)
Torque: 18.5kg.cm (6.0v) 22.8kg.cm (7.4v)
Rotation angle:360degree(PWM500-2500us)
Weight: 58gram
Motor: Coreless
Gear Train: Metal(Titanium gear)
Ball Bearing: 2BB
Dead band width: 2usc
Interface: (JR)
Wire length: 30cm
Type: Digital,middle Aluminium heat sink,Coreless,Magnetic Induction
