Mar 29, 2016, 04:34 PM
Fan of just about anything RC
SoloProFan's Avatar
Mini-Review
Eachine E10C - a CX-10 size quadcopter with 2MP camera (early work in progress)
Not too long ago we were amazed by the CX-10C, a CX-10 size quadcopter with a camera. Even though only 0.3MP, the images were quite smooth, and it was an amazing feat at that time. However, once the novely wore off, drawbacks become more and more apparent. Slow yaw rate, short flight times, and the video quality was no match for the cameras found in multirotors that were just a little bigger.
This Eachine E10C promises to be new step in the right direction, with better resolution camera, more agile flight, and longer battery duration. Can it live up to the claimed specs, or will it be more of the same?
Disclaimer: I don't get paid, or in any other way make money with reviews like these. Product specifications and quality may vary at the manufacturer's discretion, and are beyond my influence. I cannot guarantuee you will get a product that performs exactly the same as seen and described in this review. There is always room for a general discussion on the reviewed item, but no affiliate links!
For easy navigation, here's a list of contents:
1: Specifications (posting #1)
2: Unboxing (posting #1)
3: Transmitter (posting #1)
4: Flying Performance (posting #1)
5: Preliminary Verdict (posting #1)
6: Suitable for a Beginner? (posting #1)
7: Hints, Tips & Modifications (posting #2)
1 - Specifications:
First, let's start with a link and a picture:
http://www.banggood.com/Eachine-E10C...p-1039741.html
Specs according to the Banggood website:
Description:
Brand name: Eachine
Item name: E10C Mini RC Quadcopter with camera
Frequency: 2.4G
Channel: 4CH
Gyro: 6 axis
Material: ABS
Quadcopter Size: 60 x 60 x 28mm
Quadcopter Weight: 15g
Package Size: 12.3 x 7.5 x 8.5CM
Color: silver-gray
Blade size: 30mm
Flight time: 5 - 6 minutes
Flight distance: about 20M
Charging time: About 35 minutes
Battery for quadcopter: 3.7V 150mah (included)
Battery for transmitter: 2 x AA battery (not included)
Camera: 2MP 720P
Certificate: EN71,EN62115,ROSH,HR4040,ASTM,RTTE,CE.
Features:
4 channel mini quadcopter
6-axis flight control system with adjustable gyro sensitivity
With 2.0MP camera can Video/Photograph
Up / down / left / right / side flight / hover / flip / hand launch / 360°rolling
3 flight speed mode
Low voltage alarm
Battery protection
With LED light for night flight
Memory card and card reader not included
Package Included:
1 x Eachine E10C Mini RC Quadcopter With camera
1 x 2.4G transmitter
1 x 3.7V 120mah Battery
1 x USB charging cable
4 x spare blades
1 x User Manual
2 - Unboxing:
The E10C comes in a small box:
The cardboard could be a bit thicker, to stand better chance surviving shipping, but it could be worse:
Inside we find the quad, a manual, 4 spare props, transmitter and USB charger:
No SD card for the camera and/or card- reader. So if you want to shoot pictures and video, you need to source these from somewhere.
The E10C weighs 16.76 grams, on my tiny scale. As the quad looks a lot like the CX-10C, it's no surprise it uses the same charge connector, except with reverse polarity, so like the 8801 LuLa and Helicute Nano 2.0.
Side by side, apart from the obvious color differences, both quads are very similar in design:
3 - Transmitter:
This one is a little bigger than expected, wich is nice, although the sticks are still very close to each other:
It needs 2 AA cells to power up:
The transmitter has surprisingly few buttons. Cycling rates requires pressing down on the left stick, and pressing down own the right stick activates flip-mode. The shoulder buttons control taking a picture or video. Calibrating the gyro is dome by holding both stick bottom left position.
4 - Flying Performance
Arming sequence is quad on, then transmitter, throttle up and down, and ready to go. In the air one thing becomes apparent very soon. the E10C has much better yaw rate than the Cheerson. In mediun rate it's already quite lively on yaw, on highest rates, it spins like a top. So what the CX-10C lacks in yaw, the EC10 overshoots the ideal yaw speed by far. Pitch and Roll in medium rates are not that great, but the yaw speed is nice. It would have been nice if the pitch and roll of the highest rates would already have been available on the medium setting, And that highest rate would only increase the yaw.
So back to medium rates for now, since it has the best yaw setting. Control feel is a little indirect, not laggy, but more like JJ1000 vs 3015-2. Flips are not that good, the quad seems to suffer from VRS and even when starting the flip at 2 metres above the ground, it becomes a "touch-and-go" , as even full throttle can not prevent it touching the ground briefly. Maybe the battery needs to get worked in, for better recovery after a flip..
The leds are very bright, including the one showing camera status. Would make a great night flyer, no doubt.
5 - Preliminary Verdict:
The E10C certainly tries to surpass the CX-10C. With higher resolution images and video, and much faster yaw, it looks like it's a clear winner. But things are not that clear cut. The yaw is already fast on medium rates, and becomes pretty much useless on highest rates, while only on that rate, the pitch and roll are ok, and too slow on lower rates. Flips are hardly possible, as the quad drops down far, due to VRS, after making the flip.
The camera does output at the claimed resolution, but the images are not crisp, and as soon as the E10C starts moving, there is much blurring. So while in theory the E10C should give better video, the smooth low res output of the CX-10C is easier to look at.
Maybe my E10C is not fully ok, the bad flip performance could be an indication. So maybe it's not a total loss, but based upon my experience so far, I would prefer the CX-10C for now.
Pros:
- Larger transmitter than normally used on a Nano quad
- Does output images and video at high resolution, decent image quality for it's size
- Bright leds, would make a great night flyer
- Good flight time for something this small with camera
Cons:
- Overly fast yaw on all rates
- Loses lots of altitude when doing a flip
- Camera has some trouble with fast yawing.
- Transmitter is bigger, but sticks are still uncomfortably close to each other
6 - Suitable for a beginner?
Based upon the pitch angles, yes. But the yaw is way too fast for a beginner. Even on lowest rates, the top yaw speed is already faster than the max yaw speed on some quads. Also, when near full stick is given, the yaw speed takes a little "jump" so it suddenly becomes a lot faster near full stick movement. On the positive side, it's a small quad, so less likely to get damaged in the almost inevitable crash...
(to be continued)
Mar 29, 2016, 04:35 PM
SoloProFan's Avatar
7 - Camera Performance:
One of the things that will interest many people, is the camera on the E10C better than the one of the CX10 series? Well, pictures are shot in 1920 x 1080, which sounds impressive. However I am not certain if that is native resolution, or interpolated. The camera needs good light, when flying indoor, images tend to show a fair amount of noise, so you can see the small camera is struggling.
Same applies to the video, this time the resolution is 1280 x 720, but when I compare for instance to footage of the FW777-957 "Gazer", which also makes 720 videos, the E10C's camera has less definition, as well as colors being more washed out, and having more probems with fast yaw movements, video becomes a blur. If I compare against another camera that records in this resolution, the one of the WL Toys Q242G, the difference is even bigger. Not just details, but also there is much more motion blur, even when not making a fast turn. So it does offer a better resolution than the CX-10C, but lacks somewhat in smoothness.
(reserved)
Mar 30, 2016, 04:58 AM
SoloProFan's Avatar
Added pictures and unboxing info
Latest blog entry: For the love of the hobby!
Mar 30, 2016, 02:28 PM
Pixelpeter's Avatar
Those wings with lens on the box look remarkably similar to those of the winged eye on the Cheerson CX10C
Cannot wait on the results out of the camera; the CX10C was quite a surprise in that field.
Mar 30, 2016, 03:01 PM
SoloProFan's Avatar
It's clear that Eachine has kept a "close eye" on the CX-10C. The body is so close in shape, that it looks like they made a clay mold of the Cheerson.
Mar 31, 2016, 12:26 AM
SoloProFan's Avatar
Update with pros and cons, and some comment on video and image quality.
Mar 31, 2016, 01:22 AM
Maybe you got a lemon?
Mar 31, 2016, 01:53 AM
pretty sure the E10C and the CX-10C are made in the same factory.
Mar 31, 2016, 02:03 AM
SoloProFan's Avatar
Could be, considering the poor flipping performance.
I doubt it. The models look very similar but parts are not 100% identical. It feels more like a copy, than a rebrand.
Mar 31, 2016, 02:26 AM
Pixelpeter's Avatar
I've ordered one as I do like these small camera quads. Will see what it is like.
Mar 31, 2016, 04:58 AM
At first I thought this was a rebrand of the cx10c. But there are obvious differences in the TX and quad itself. As well as differences in flight characteristics. I was interested if it truly had a 720p 2mp camera. You seem to indicate it does but at the same time does not perform as well as the 0.3mp camera in the cx10c.
Anyways, good detailed review.
Mar 31, 2016, 06:10 AM
Vox Furry Regem
Lycan Animal's Avatar
Great review.
Same weight as the CX 10C and CX 10W?
I found flying the CX 10W with a Tx it would just drop to the floor on flips and struggle to regain height. It always felt way too heavy for the motors and props.
Mar 31, 2016, 06:18 AM
SoloProFan's Avatar
Originally Posted by Lycan Animal
Great review.
The E10C is heavier, CX-10C is around 15g, the E10C around 16.75g
Mar 31, 2016, 05:44 PM
Pixelpeter's Avatar
The battery is slightly bigger
Apr 01, 2016, 11:09 AM
Registered Fiend
microrcfiend's Avatar
I didn't think the video was bad at all considering the size of this quad and after the CX-10W which was just un flyable with any sort of precision, the little TX is so welcome.
Interesting what you say about the limited rates though SoloPro, I found them to be higher than my first edition CX-10 although that still slight trumps this E10C in terms of flying precision even with a smaller TX still.
I do wish they would/could make a quad that didn't have trim that drifted in flight as these little guys have so much drift that it starts with a perfect hover and by the end full forward isn't enough to stop it drifting backwards. I'd rather that and rate mode were used over all stupid auto flips and HH modes and other useless 'features'.
I do seem to have a quad with the occasional funks though, twice in this video before the cat comes to play the quad dives off to the side way faster than if you just jammed the sticks and loses height. Watching it back after made me think maybe props were slipping so will try tacking them on with CA but has anyone else had this?
Eachine E10C - Maiden - massive quad copter terrorizes local cat (5 min 1 sec)
