Dec 26, 2016, 04:25 PM
betaflight_3.1.0_FLIP32F3OSD
You can try it
Dec 28, 2016, 11:55 PM
Family, Work, FPV!
Realms's Avatar
Originally Posted by Snitch7
Hi,
I have this board working fine with d4ii Rx and telemetry.
But no OSD.
I have CAM to OSDIN
and Vtx to OSDOUT
On my goggles all channels are snow except the correct one which is a dark grey screen - its clearly sending something - but is not a picture.
When I join CAM and Vtx together, I have a picture. But no OSD obviously.
Am I wiring up something wrong?
Thx
Did you flash it with MWOSD?
Jan 01, 2017, 08:44 AM
Originally Posted by cterraza
You can try it
Great just in time.. I just broke the USB port off my FC.
Anyone know where I can buy this FC these days? Any other FCs that have an integrated OSD that you would recommend?
Jan 01, 2017, 02:18 PM
Physics, or is it fizzix?
flyandride's Avatar
Every place that used to sell them seems to be out of stock. After getting 2 bad ones out of 4 bought and having a third fail I would not buy another. I tried an Omnibus F3 but would stay away from those. They work but the maker still has not gotten RSSI working and has put out 4 different Omnibus boards.
Jan 01, 2017, 11:56 PM
I believe they can still be had here:
http://www.readytoflyquads.com/flip-32-f3-osd
Jan 02, 2017, 07:05 AM
Thanks for this.. I was looking at the Omnibus. You probably saved me a bunch of time. Looks like theres only one place to get this and it's hit or miss with the seller and the product. time to look for space on my quad for another board and a MicroMinim OSD.
Jan 02, 2017, 10:28 AM
flyandride's Avatar
Before you order from RTFQ, read the following threads.
https://www.rcgroups.com/forums/show...sponse-Help%21
https://www.rcgroups.com/forums/show...-and-dishonest
Jan 03, 2017, 12:49 PM
Bro thanks for the heads up, good looking out. Unfortunately I have already been burned by this seller.. never going back, not even even to his website. Looks like I'll be going for something else.
Jan 08, 2017, 12:45 AM
Hello,
I just received my SP Racing F3 with OSD. I connect it on clean flight through the serial usb adapter. Everything was good. Then I upload the latest firmware.
I selected "SPRACINGF3OSD" and versions 1.14.2.
The upload was ok. Then it's no more possible to connect to the board with clean flight.
Do you have an idea?
This is my board:
http://img15.hostingpics.net/pics/892050Sanstitre.jpg
Jan 18, 2017, 12:32 PM
Originally Posted by yop21
Hello,
This is my board:
I have the same board, from Hobbyking.
I'm starting my 'tussle' with it - and finally, I think, have changed the Cleanflight default software to INav, and have updated the MW_OSD software/configuration.
Did you update with Cleanflight? If you used another firmware, like INav then I think you may not connect.
Have only done this on the USB PC connection so far, so need to double check it's really on there OK.
I really hate this stupid couple of solder blobs to short to change the firmware - one needs Superman's vision and 5 hands! The biggest problem I had was making sure I had the right port with the right speed (although the default Cleanflight connected fine).
Anyone add some small leads somewhere to make it easier, and in case those micro-pads get damaged? If so, where?
Jan 18, 2017, 06:01 PM
Got the OSD showing on the VTX signal to my goggles, but doesn't look like the OSD data is reflecting the FC data.
I suspect they've simply added the OSD hardware in, but there needs to be some other hardware connections/software config.
Anyone have any idea what's required?
Jan 25, 2017, 10:47 AM
New target FLIP32F3OSD
Good news everyone,
@AndersHoglund added a new target FLIP32F3OSD, so now you can compile the lastest release with out problems
F3_TARGETS += $(TARGET)
FEATURES = ONBOARDFLASH
TARGET_SRC = \
drivers/accgyro_mpu.c \
drivers/barometer_ms5611.c \
drivers/barometer_bmp085.c \
drivers/barometer_bmp280.c \
drivers/compass_ak8975.c \
drivers/compass_hmc5883l.c
ifeq ($(TARGET), FLIP32F3OSD)
TARGET_SRC += \
drivers/accgyro_mpu6500.c
else
ifeq ($(TARGET), ZCOREF3)
TARGET_SRC += \
drivers/accgyro_mpu6500.c \
drivers/accgyro_spi_mpu6500.c
else
TARGET_SRC += \
drivers/accgyro_mpu6050.c
endif
endif
Jun 05, 2017, 12:17 PM
Is there a iNav-build for this board
Hi,
anyone know if there is a iNav-build that works for this board? Tried SPRACINGF3MINI and it boots, but PWM-outs in F_cke_-up order :-{
