Build Log
Balsa vs. Depron: Jupiter Scout free download plan
A practical comparison: Same model, same gear, nearly same method of construction. Jupiter Scout is a 64 cm span model with RET controls. You decide if it will be made of balsa or depron!
Free download is here on Modell-Aviator.de: http://modell-aviator.de/files/av051...iter-scout.pdf
Neat design, I'm going to print the plans out for sure!
Was there a winner? German escapes me.
Cute model. What is the genesis of the name ? Jupiter Scout congers up a different image - maybe something with jets .
Oh all right, I printed the plans and I have a suitable motor and some 5 grams servos just sitting there glaring at me. So many models - so little time. Oooo, I have a pair of little Trexlers available too. |
I like it!
Astounding similarities to my own design Big Annie. |
A neat design.
But it could be argued that Balsa and Depron have rather different mechanical properties so a design best suited to one will not make best use of the properties of the other. Depron is much lighter and more flexible than balsa so the details of the construction should be rather different even for a plane of the same overall dimensions. |
Der Lazy Bee!
Depron is much lighter and more flexible than balsa so the details of the construction should be rather different even for a plane of the same overall dimensions.[/QUOTE]
Agreed. This comparison does not show if balsa or depron is better for parkflyers in general. It shows the differences for this model. I chose this size and type of construction because it is well suited for both materials. |
Result of the balsa - depron comparison
Here is the result:
Balsa version: 210g Depron version: 165g Both fly extremely well, stable and agile at the same time. The balsa version is a bit faster because of the higher weight - so it is the better outdoor flyer, especially in windy conditions. Depron is better for indoor flying or very small spaces. It also has a better thrust to weight ratio so it is easier to do some weird 3D manoeuvers. Now the irrational factors: The balsa version is more precious to me, though the difference in cost is marginal. Because of that, I fly more adventurously with the depron version. Both are great fun! |
...thank you Thomas for this great design, videos and all the information on this model!
I'm a balsa lover but I need an indoor model at the moment therefore have started building the depron version first. This is my first depron/foam build so any information from all of you is very usefull to me! I will post pictures of my build soon! Thanks again. |
build pics
So here we go.
Depron: all 3mm with 1,5mm carbon spar under the wing Glue: uhu por and low temperature hot glue Balsa: 2mm Wing and fuselage, 3mm stabilizer and fin, no spar Glue: cyano ImagesView all Images in thread
Thomas, thanks for the con. pic!
Here some pictures from my depron JS! |
