Mar 23, 2016, 05:15 AM
New Product
JXD 510G 5.8Ghz 2MP FPV RC Quadcopter
JXD 510G FPV 5.8Ghz 2MP Camera Altitude Hold CF Mode 3D Flip 4CH 6Axis RC Quadcopter http://www.geekbuying.com/item/JXD-5...er-365401.html
Description:
Brand: JXD
Model: 510G
Color: Black
Frequency: 5.8Ghz
Channel: 4 CH
Gyro: 6 Axis
Flight Time: About 6 Minutes
Remote Control Distance: About 80 Meters
Recharging Time: About 70 Mins
Battery For Quadcopter: 3.7V 800mAh (included)
Camera: 2.0 Megapixel
SD Card: 4G
Product Size: 29.5X29.5X10.7 cm
Function: 5.8Ghz 720P FPV / High Hold Mode /CF mode headless/one key return/up/down/forward/backward/side flying/3D Flips & Rolls /hover/ HD photo and video
Features:
5.8Ghz 2MP FPV
High Hold Mode
2MP camera for Video/Photograph functions
Headless Mode,no need to adjust the position of aircraft before flying .
One key to return function makes it easily to find the way home.
4 Channel which can do ascend, descend, forward, backward, left sideward fly, right sideward fly and rolling 360
It has 6-axis gyro which can have more stable flying and be easy to control
360 degrees flip
Battery protection
Package Included:
1 x 510G RC Quadcopter
1 x Transmitter
1 x 2.0MP FPV Camera
1 x 4.3 inch Monitor
1 x USB Cable
1 x 4G Memory Card
1 x Card Reader
1 x FPV USB Cable
1 x 3.7V 600mAh Li-Po Battery
4 x Spare Main Blade
1 x Screwdriver
Apr 03, 2016, 09:46 PM
Has anyone used the jxd 510g drone to see if it has any jello?
Apr 04, 2016, 09:20 AM
Jxd 510g
Do anyone know the difrent between 509 & 510?
What is the upgrade?
Apr 04, 2016, 10:21 AM
I would also like to know the differences between jxd 509 and jxd 510.
Apr 05, 2016, 11:27 AM
Does anybody have chance to learn what has changed?
Apr 07, 2016, 07:40 AM
foamies never die
the_bunker's Avatar
Dunno, but the 509G had some bugs with the barometer control - some people reported they couldn't get it to come down !
So, hopefully they fixed that at least...
Apr 07, 2016, 08:56 AM
I contacted to the manifacturer indirectly and this is the reply i received:
"Not much difference in performance, but look different from model."
Apr 08, 2016, 01:45 PM
One obvious difference I see is the 800mah battery supplied vs the 600 for the 509G. I just bought a pair of 850s for my 509G and they fit in easily. I just got it yesterday and flew it on the charge as it arrived. Everything worked perfectly. I have flown many different rc models, this is by far the most stable and easy to fly I've ever used
Apr 08, 2016, 01:51 PM
Getting it to come down is as easy as holding the left stick down and then inputting directional control and fly it down, as opposed to only holding the left stick down.
Apr 09, 2016, 09:10 AM
How long did the flight last with 850? What were on/off?
Apr 10, 2016, 06:51 PM
Drone Builder
The JXD 509 and now the 510 are nice stable, responsive flying machines. With a little software tweaking on the autolanding feature, a stiffer/reinforced frame to eliminate video jello and perhaps a remotely controlled tilt camera gimbal they would have a real winner. I personally like the no fly away feature where the unit will autoland on LOS and low battery. They could skip the flip button and replace it with a linear tilt control for the gimbal. I'm hoping JXD reads these fourms.
Apr 11, 2016, 09:41 PM
You want to know the big difference ? It is the first ever toy grade FPV quadcopter to support acro mode, i am not sure but it is written on this image "3D full-flight" ( http://hobbywow.com/desc/JXD/JD100/JD100_6.jpg ) and 3D is the second name for acro mode.
So it is by far the best quadcopter to learn fpv racing/freestyle in the market. It also have propeller guards, overall it seems more resistant to crashes and the look is much more agressive. Also the battery was a 800 mAh for the 509G now it's a 600 mAh for the same flight time.
A better link to buy it: 78 euros on gearbest http://www.gearbest.com/rc-quadcopters/pp_345149.html
And 5 batteries + multi charger for 13 euros http://www.gearbest.com/rc-quadcopte...pp_279073.html
Apr 12, 2016, 12:56 AM
Fan of just about anything RC
SoloProFan's Avatar
Originally Posted by Linko
You want to know the big difference ? It is the first ever toy grade FPV quadcopter to support acro mode. So it is by far the best quadcopter to learn fpv racing in the market.
The 510? Does it also have wide enough FoV for the camera? Most cheap FPV quads drop the ball there. Pretty hard to learn FPV with only 70 degrees vision.
Latest blog entry: For the love of the hobby!
Apr 12, 2016, 07:14 AM
I think it's only a 70 degrees angle and you can't orient the camera, we will have to wait. But currently it win in a lot of category:
_cheapest FPV quad, by adding 5 extra batteries it cost under 90 euros
_ first toy with both FPV and acro mode
_ ultra durable each arm is attached to each other + propeller guards + foots making it a must for beginners and discover acro flight (you won't need a lot of extra propellers with the guards and breaking an arm is almost impossible even at full speed)
_ it is the most aggressive looks i have seen, cool radiocommand and neat analog in metal considering the price
_ LED bulb lights making them visible even when it is sunny and far at night
_ popular and very cheap batteries
_ the throttle goes back to center, every quad should do that it's way better than the altitude hold
_ magnetic motors more energy efficient and durable it's similar to a brushless motor that is why it can fly 10 minutes with 600 mAh.
_ 360 degree eversion
Apr 13, 2016, 06:43 AM
TechTronic9000's Avatar
I have a coupon for the JXD 510G with altitude hold. It's just under 80$ (79.9) with free shipping from GearBest. Just use the code: JR10G
