XK X251 whirlwind (in construction) - Page 5 - RC Groups
Mar 31, 2016, 09:53 AM
Originally Posted by SeByDocKy
The Syma X5 FPV kit comes with a 3 position 1.25mm mini JST connector. We need a 4 one here ...
The world is a cruel place. Thanks though.
Apr 03, 2016, 12:42 AM
Is there an adapter to fit other props?
Apr 03, 2016, 02:48 AM
SeByDocKy's Avatar
In fact IMHO, the main problem is to find some prop with a low profile hub (of 3mm).
Classic props are more 6mm
Latest blog entry: Youbi XV-130 130MM FPV Racer
Apr 07, 2016, 06:48 AM
SeByDocKy's Avatar
New demo flight:
XK X251 new maiden demo flight (Courtesy Banggood) (7 min 0 sec)
Apr 07, 2016, 01:09 PM
I dont like crashes!
Not so much traffic in this thread. I thought that the X251 would be much more popular!
Apr 07, 2016, 01:15 PM
The restriction to stay with stock props isnt very satisfying!
With a brushless quad it should be possible to use different kinds and sizes of props.
Apr 07, 2016, 01:21 PM
PALE OTAK KAU!!
KCreep's Avatar
It's not officially out yet and currently Seby is the very few that have the pre-release sample. Have to wait a couple more weeks to see some other user experience and opinions.
Like they say on TV: Stay Tuned!!
Apr 07, 2016, 01:44 PM
Fan of just about anything RC
SoloProFan's Avatar
I am still trying to get one, but seems there are very few available.
I agree, that is an area where the JJRC X1 does it better. It can use basically most popular 250 size props, I currently fly mine with 5046BN instead of the stock 6040. Without the massive improvement in handling that the different props brought to my X1, I would have either sold it, or removed the motors, to install on a different frame, or replace the electronics.
Apr 07, 2016, 01:48 PM
SeByDocKy's Avatar
I undestand that the non-ultra large choice of prop can handicap the XK X251.... but the original are really solid and well balanced .... What else ?
Apr 07, 2016, 02:03 PM
SoloProFan's Avatar
True, I only replaced my X1 props because the stock ones didn't give the right feeling. With the X251 the handling seems almost perfect, out of the box. But still it does force the owner to stock up on stock props, while with the X1, you can get props from many sources, if you break some.
Apr 08, 2016, 07:07 AM
X251 Availability
Any one knows when is the availability?
Apr 08, 2016, 05:14 PM
Lets say the stock props for an brushless quad are 6040.
With 6020 or 7024 props I will get much more flight time. Also lower speed.
Can use also bigger batts with the gained thrust.
With a 5045 or 5050 BN I will get much more speed. Also lower flight times.
Use smaller batts decreasing the AUW but will have a rocket for a short flight time.
More possibilitys depending to my needs?
Apr 09, 2016, 12:40 AM
SeByDocKy's Avatar
I see what you mean .... and yes these low profile 3mm hub props are one the weak point of this machine ...I didn't find any compatible yet. Maybe need a shaft adaptor ?
Apr 09, 2016, 03:38 AM
SeByDocKy's Avatar
Add in #1 the official Award
Apr 09, 2016, 01:31 PM
Are shaft adapters available for this kind of issue?
Would be a pity if this great quad hadnt the possibility to use different props.
