Sep 01, 2019, 07:52 AM
Loki's Minion
Tower669's Avatar
Looking good there fella. That one should go together fairly quickly.
Latest blog entry: Vuzix iWear
Sep 03, 2019, 11:12 AM
Wa hooo the Silicon Conformal coating arrived just now so I raced to my shop and coated all the ESC 's and the strobes. Water protection don't ya know.
Next is to do the final inspection of the connections then if they pass. Do the shrink wrap and get them into the tubes.
Then I can crimp or solder up the ends. Sahh Wheet
good times lol
Sep 05, 2019, 07:02 AM
military drone clone update 09-05-2019
Well this morning I got to pull all the cables through and mount the strobes.
Just needs to crimp up the connections tomorrow and the arms can be mounted.
Sep 11, 2019, 08:03 PM
military drone clone update 09-11-2019B
So started mounting arms to frames.
Here is a couple snaps to show how clean the build is working out so far. I know its early days yet..but so far looking good.
Sep 13, 2019, 09:58 AM
Military Drone Clone Update 09-13-2019
So this morning I tried wiring up a front motor arm.
Crazy to say but it was harder then the back ones.
Sep 14, 2019, 06:09 PM
military drone clone update 09-14-2019
Finally finished one drone and its main connections to the motors.
Lookin pretty clean.
Also some photos on the folding mech as it is now after all it's evolutions.
Sep 14, 2019, 09:28 PM
Loki's Minion
Tower669's Avatar
Are those the esc servo connections? You dirty dog, you!
Sep 15, 2019, 09:49 AM
ESC connections. Power to the ESC and power and signal to the Strobes.
Sep 15, 2019, 05:40 PM
I have a second frame to put the last two arms on then its time to test the board for cross connections.
Gnd to Strobe Signal
ESC Signal to 5vdc
GND to PWM for the ESC
Pwm to Tel
if this passes then its power up and look for smoke. If that passes then its on to Hall sensor connections and then FC connections.
Then video and lastly gimbal.
Sep 16, 2019, 05:57 AM
Loki's Minion
Tower669's Avatar
Which type of gumball have you settled on?
Sep 16, 2019, 07:06 AM
This is the gimbal I have and the frame was designed to support.
I don't think it's available anymore..but it may be found used. If you find a different gimbal and need some help building mounts or something like that..Let me know
https://fpvmodel.com/products/fpvmod...14059227349045
Sep 16, 2019, 08:56 AM
Locking Mech Details
Scott here are some additional details around the locking mech.
The first diagram show the new versus old parts. These need to be taken into account if you want to move to the new mech.
Second shows the filed down screw that locks into the plate and the 3rd is the 3d part.
Sep 16, 2019, 10:02 AM
Loki's Minion
Tower669's Avatar
Bob Saget! That sucker is worth a few pesos!
Sep 16, 2019, 11:15 AM
yup
That doesn't mean a regular gimbal can't be used.
All that we need to do is sort out the mounting and if its sbus or pwm controlled.
Sep 16, 2019, 04:19 PM
military drone clone update 09-16-2019
Ok arms are now on all frames.
Getting ready to do the next batch of tests.
I need to check for accidental cross connections.
