Mar 22, 2016, 06:08 PM
Question
Throttle stick is not working but others do
Hi,
I'm working with:
- Board Multiwii 328p
- Radiolink AT10
- Receiver R10D
I have configured config.h:
#define QUADX
#define MINTHROTTLE 1150
#define MAXTHROTTLE 1850
#define MINCOMMAND 900
#define I2C_SPEED 400000L
#define FREEIMUv035_BMP
#define ALLOW_ARM_DISARM_VIA_TX_YAW
After binding the radiolinks at10 with my receiver I have connected via USB my labtop with the board and in MultiWiiConf I can see how stitches YAW, PITCH and ROLL work perfectly but the THROTTLE one remains static at 1500.
I have switched the wire from pin1 with the one in pin3 and this test has certified that my radiolink throttle stitch work perfectly.
Any help will be welcome!
Mar 22, 2016, 09:03 PM
Do you need to define the mid throttle as well?
Worth a try as I am still new to all this!
Mar 23, 2016, 07:47 AM
Team AlienWarpSquad
None of the #defines you posted is the problem.
Moving the RX throttle output to a different WMC input is a GOOD test and proves the TX/RX works.
So the problem is the connection to the MWC. So either you have the wrong pin or this pin is disabled or bad for some reason.
Do you have the correct Board??
Post link to the EXACT board if you want verification.
Also picture of your board with RX connections.
Mar 23, 2016, 05:15 PM
Hi,
I have tried connecting the throttel stitch (channel 3) in radiolink at10 and receiver R10D to pin 1 (throttle) and does not work. Later I have tried to connect it to pin 3 (pitch) and the throttle stitch have moved perfectly. Hence the RX/TX looks correct.
Thanks a lot for your assistance!
Mar 23, 2016, 08:06 PM
Channel mapping order correct? ie TAER1234 or whatever...
Mar 24, 2016, 07:19 AM
Team AlienWarpSquad
The OP is using MultiWii NOT CF and does NOT have Channel MAP.
Still same guess:
Post a LINK to the MWC board you actually have.
Mar 24, 2016, 02:12 PM
Hi,
My board is Board Multiwii 328p you can find here:
https://www.hobbyking.com/hobbyking/s...Comp_Port.html
I have tried with
and
#define HK_MultiWii_328P
And throttle does not work in both configurations.
Regarding to order:
Roll: channel 1
Pitch: channel 2
Throttle: channel 3
Yaw: channel 4
Thanks a lot,
Mar 24, 2016, 02:19 PM
Hi,
My board is the following:
I have tried both with:
and
And throttle stitch does not work in both configurations.
Regarding the mapping order:
Roll: channel 1
Pitch: channel 2
Throttle: channel 3
Yaw: channel 4
Thanks a lot.
Mar 24, 2016, 05:05 PM
I see, ok, thanks Waltr... please excuse my relative newbness!
Mar 24, 2016, 08:12 PM
Team AlienWarpSquad
Originally Posted by osegarra
Hi,
and
Roll: channel 1
Pitch: channel 2
Throttle: channel 3
Yaw: channel 4
Thanks a lot.
According the the config.h in the "Files" on HK's product page you should use #define HK_MultiWii_328P
You did find these and opened/read each one, right?
Did you try a different RX channel into the throttle pin (THR) of the MWC?
If this doesn't work then it is possible you have a board with a bad processor pin or soldering.
You can try examining the processor's pins to see if they are properly soldered or return it for refund or exchange.
