Mar 20, 2016, 08:53 PM
Question
Which Prop For Spartan w/Upgraded Motor & ESC????
So I upgraded the Spartan to the Leopard Motor & 180 amp esc, so now I have to upgrade the shaft to 3/16" as well which means a new stinger also! So which prop will suit this upgrade best???? Maybe someone out there that has been there already can answer this question for me.
Mar 20, 2016, 09:37 PM
ApexpredatorGT's Avatar
Which leopard motor?
Mar 21, 2016, 04:21 AM
I think it's the 4082-1600KV but I'm not really sure, it was already in the boat when I bought it and it's in the waterjacket so I guess I need to take it out & find out.
Mar 21, 2016, 05:42 AM
r46
r46
huggin dat apex!
r46's Avatar
What voltage be using?
Mar 21, 2016, 06:04 AM
I'm running 6S 22.2v
Mar 21, 2016, 09:13 AM
You have a big esc, plenty of head room. I would start at around 45mm just to see where you're at.
Mar 21, 2016, 09:19 AM
So maybe something like in Octura X445?
Mar 21, 2016, 01:13 PM
That would be an ideal prop. Or the 215 Prather.
I'm not trying to sway you to CNC since they cost a little more, but I am getting great results in every boat I've ran cnc props on. Including the Spartan when I had it.
Mar 21, 2016, 02:19 PM
Those were exactly the two props that I was looking at and I really like the Prather 215 but the only problem is that I can't find it in stock anywhere already sharpened and balanced because I'm still new to the Hobby and I haven't learned how to sharpen or balance a prop yet.
Mar 21, 2016, 02:41 PM
CNC props might be a better option for you then. I am using the OSE cnc props with excellent results.
I'm pretty sure OSE has a 42 and 45 or something close in cnc.
Mar 21, 2016, 08:33 PM
Yea, they have this one in stock;
CNC Prop 45mm - 3/16" bore
CNC 4514 Magnalium 7075 propeller.
Is that the one you had in mind?
Mar 21, 2016, 08:43 PM
The 45mm prop should give a nice boost in speed.
You will need this also
http://www.offshoreelectrics.com/pro...?prod=ose-1030
Mar 21, 2016, 09:24 PM
I would still need that adapter even if I switch to a 3/16" stinger & 3/16" shaft????
Mar 21, 2016, 11:08 PM
Sorry, I forgot you mentioned you were upgrading. You won't need the adapter with the 3/16 shaft/stinger
Mar 22, 2016, 07:31 PM
I have no choice at this point, first time in the water after the motor & esc upgrade it snapped the stock shaft like it was a Candy Cane!! So I'll do it right this time and have a much faster boat on my hands. Thanks for all the help!!
