Mar 18, 2016, 09:52 AM
Question
1/5 and 1/8 Off-Road LED Light Set with Functional Brake Lights
Hi newbie here, can someone please advise why my front led lights dim when i turn the steering . The instructions clearly states that these lights are powered from the car's esc. If i connect to a separate power source then the brake lights will not work.
I could provide a separate power to run the front lights only, but any additional advice would help,
FYI from the manufacturer
This off-road light system is a great choice for your 1/5 or 1/8 scale buggy/truggy/truck! It features super bright LEDs for both the headlights and taillights. It uses the ESC's throttle signal to trigger the brake lights during braking to add the ultimate in scale realism to your model.
This LED light set is powered by your model's receiver, so there is no need for a separate power source/battery. This keeps things simple and easy, it also saves weight.
Features:
• Easy to install
• Super bright LEDs
• 4 x headlights and 2 x taillight/brake lights
• Easy connection inline with your model's ESC channel
Specs:
Working Voltage: DC 5V
Working Current: 600mAh
Weight: 20g
