Defective Runcam Swift 2?
I just got my new Runcam Swift 2 a few days ago and finally got around to installing it tonight.
I went outside to just give a quick test flight and barely got the quad back the image quality was so bad I couldn't make out tree tops etc and almost lost it up in one. When I got it back I double checked all the connections etc, all that looked fine, I even plugged in my old camera in place of the runcam and it looked fine. Attached is an image of what I am seeing in the goggles (Fatshark dominator v3's and EV800) both looked he same. Do I have a faulty camera? I ordered this from one of runcam's authorized dealers. |
Swift Mini Coming!!!
https://oscarliang.com/runcam-swift-...mera-overview/ |
No I didn't. Just switched to my old camera. I do not have much time for this now though. I emailed runcam and they want a video showing a problem, I am not sure what they want to see if it is not working Have to find some time, switch cameras and send them a videos. I can post here the result of it.
Ugh wish I had found this thread earlier. I'm currently sitting on 2 dead runcam swifts. One with the black screen but can see the OSD issue the other completely dead. One has been dead for a few weeks the other just going out today.
The one that is completely dead has been so for a few weeks but happened while flying normally. The other that kicked it today and now has a black screen was working great for about half the flight and then died. Other cams work great and have always fed both off of clean 12v. I was thinking of giving the swift 2 or mini a try, but now thinking of going to Foxeer... |
Is the RunCam Swift still being manufactured? I checked with four different USA vendors today, three of them no longer carry the Swift at all and the fourth one is sold out.
Version 2 is out. I hope it's better than the first.
https://www.readymaderc.com/store/in...dea4-142637829 |
@Runcam
Is the SWIFT 2 case compatible with the SWIFT original? These cases are expensive and I rather only have one spare for my SWIFT RR and SWIFT 2. Please confirm, pictures say they are the same except for a mic hole. Even if the backplate is different, we usually break the case body over the backplate. Otherwise I am going back to the HS1177 which did have cheaper cases. |
I did find a USA vendor with the Swift 1 in stock but it's the same price as the Swift 2. |
It says right on the picture. You can use the case of the Swift 2 for the SWIFT if you don't mind the mic hole and the connector place of the backplate. But the case of the SWIFT 2 is not compatible with SWIFT. |
