Mar 17, 2016, 09:52 AM
Car Bashing
Jym73's Avatar
Mini-Review
WLtoys K929 1/18 4WD desert buggy
I received a WLtoys K929 1/18 4WD desert buggy from gearbest.. It is at 40$ on EU warehouse and 47$ on US WH for the moment (17 march 2016).
Not a new car at all but i will give my thought and impression.
Shipment packaging :
Well packaged and box reinforced.
Name: WLtoys k929 box 1.jpg
Description: Name: WLtoys k929 box 2.jpg
Description: Name: WLtoys k929 box 3.jpg
Description:
Obviously it come in an other strong box with bubble plastic.
Box :
Name: WLtoys k929 box b 1.jpg
Description: Name: WLtoys k929 box b 2.jpg
Description:
Name: WLtoys k929 box b 3.jpg
Description: Name: WLtoys k929 box b 4.jpg
Description:
Box content :
Name: WLtoys k929 box content.jpg
Description:
- Car.
- Radio.
- 1 7.4V 2s 1100mah battery.
- 1 plastic tamiya wrench.
- Manual.
- Charger.
- Charger adapter.
Car design :
Name: WLtoys k929 design .jpg
Description: Name: WLtoys k929 design 1.jpg
Description:
Wheels seems a little bit small compared to body.
We can slightly change body design :
Name: WLtoys k929 design 3.jpg
Description: Name: WLtoys k929 design 4.jpg
Description:
Without roof, fake spare wheel and wing. This the configuration i prefer.
Name: WLtoys k929 design 5.jpg
Description: Name: WLtoys k929 design 6.jpg
Description:
Without roof only.
open the body :
Rear clips access is a little hidden by the fake spare wheel.
Name: WLtoys k929 body rear clips.jpg
Description:
Body move from the rear. There is a fixation on front :
Name: WLtoys k929 body open.jpg
Description:
Roll cage :
Name: WLtoys k929 roll cage.jpg
Description:
Mounted with screws.
Size comparison :
Name: WLtoys k929 size comparison.jpg
Description:
From left to right : BZ444 1/10, HuanQi 1/16, WLtoys K929, WLtoys A212 1/24.
Plastic :
- A-arm : quite rigid but have a little bit flexibility.
- Chassis plate : quite rigid but have a little bit flexibility.
- Upper deck : thin and very soft plastic.
Name: WLtoys k929 plastic upper deck .jpg
Description:
- Linkage : quite soft plastic.
Name: WLtoys k929 plastic linkage .jpg
Description:
Prevent from breakage on hub carrier but can do bend dog bone by wheel's axle's cup.
- Knuckle, C-hub, Hub carrier : quite rigid but have a little bit flexibility.
- Roll cage : quite soft plastic :
Name: WLtoys k929 plastic  body cage .jpg
Description:
Name: WLtoys k929 plastic body cage 1.jpg
Description: Name: WLtoys k929 plastic body cage  2.jpg
Description:
Transmission :
- Plastic center drive shaft.
- Plastic diff. out drive.
- Steel dog bone.
- Steel wheels's axles.
Ball bearing :
- 7x11x3 on bevel gear and diff. qty 6.
- 8x12x3.5 on spur gear qty 1.
Bushing :
- 4x8x3 and 8x12x3.5 in hub carrier.
Gear box :
Name: WLtoys k929 diff. gear box.jpg
Description: Name: WLtoys k929 bevel gear diff. gear box.jpg
Description:
Diff. :
Name: WLtoys k929 diff. open.jpg
Description:
4 small planetaries on steel axle.
Motor pinion mesh :
Name: WLtoys k929 motor pinion mesh.jpg
Description:
Imo too tight on spur gear. Not adjustable without do modification.
Motor pinion should be 0.7 mod. Hard to find different tooth number of this module.
Wheels and hex hub :
Name: WLtoys k929 wheels.jpg
Description:
SCT design. Without foam.
Name: WLtoys k929 wheels hex hub.jpg
Description:
7mm.
Shock absorber :
There is a little bit oil inside bt quite empty.
Name: WLtoys k929 shock absorber.jpg
Description:
It seems that they can be filled with oil. 2 small o-ring at the bottom held by a cap clipped.
Electronic :
Servo size :
5 wires, so we must change esc and receiver if we want to only upgrade the servo.
- thickness : 13mm.
- Width : 29mm.
- Height : 29mm.
- Height to fixation : 19mm.
Batterie :
Name: WLtoys k929 batterie.jpg
Description:
Top : WLtoys 1/18, Bottom : 18600 7.4V 2S.
Battery size :
- Thickness : 17mm.
- width : 30mm.
- lenght : 52mm.
ESC :
Rx/ESC 2 in 1, waterproofed by a kind of transparent silicon.
Name: WLtoys k929 esc waterproofed.jpg
Description:
First thought :
- Technical design seems not too bad.
- Don't tight too much screws as they can strip plastic.
- Soft plastic on roll cage will surely well protect the car.
- I will try to fill shock absorber.
- Body's design isn't the most beautiful for this version. Paint job to come ^^.
First test :
I tested the car during 1 minute only. Transmission done a "strange" noise. After opened gear box i discovered that 1 ball bearing on front diff. was missing :
Name: missing ball bearing.jpg
Description:
I didn't read that this can happen often on WLtoys 1/18. 7x11x3 ball bearing is on the way.
Modifications and adding :
Motor protection :
The only thing i done before test it is to add a protection on the motor to avoid the problem i had with the HuanQi 1/16 and a small pebble :
Name: WLtoys K929 motor protection.jpg
Description:
Synthetic tissu used for filtering.
Motor pinion :
Two things :
1 - motor pinion is too thigh on spur gear. I enlarged the upper screw hole (no need to enlarge it too much) to change motor position :
Description: Name: WLtoys k929 motor pinion mesh mod.jpg
Description:
Left : before mod. Right : after modifcation.
2 - Motor pignon alignment isn't good with spur gear :
Name: WLtoys k929 motor pinion alignment bad.jpg
Description:
We can see that there is worn trace on spur gear and motor pinion but not on all the surface of the teeth :
Name: WLtoys k929 motor pinion alignment worn.jpg
Description:
Trace is black on spur gear and more shiny on motor pinion.
I have done 2 things to straigthen this. Remove the heatsink "glue" who is under motor mount and who doesn't help to have motor support flat on the chassis :
Name: WLtoys k929 motor mount heat disipator.jpg
Description:
Imo this heatsink is useless.
And bend a little bit motor mount to have a better angle. Result :
Name: WLtoys k929 motor pinion alignment good.jpg
Description:
I must removed motor heatsink because there is not enough place for it under the motor now. I should glue it back, without glue it won't stay in place.
Drive train :
Only replaced 8x12x3.5 and 4x8x3 bushing by ball bearing.
Spur gear box :
As i do on all my cars to sealed gearbox, i added thick grease on every cover's edge of spur gear cover. Works pretty nice :
Name: WLtoys K929 dust on spur gear cover.jpg
Description:
Name: WLtoys K929 dust on spur gear cover inside.jpg
Description:
Videos :
Stock speed test :
• WLtoys - K929 - Stock : speed test • (3 min 9 sec)
Not too bad. It seems that the too tight motor pinion on spur gear make a noise that i don't like. I won't wait too much to do a modification.
Modified speed test :
• WLtoys - K929 - Modified : speed test • (2 min 31 sec)
BMX track :
• WLtoys - K929 - BMX Track • (10 min 25 sec)
I didn't opened spur gear cover since my BMX track bashing, here is the result :
Name: WLtoys 1 18 vortex K929 spur gear cover dust.jpg
Description:
Name: WLtoys 1 18 vortex K929 spur gear dust bashing.jpg
Description:
Motor pinion and spur gear stay clean. Thick grease on cover edge works with me.
Parts compatibility :
1/18 vortex is also sold by hobbyking :
Racing buggy : spares .
Short course : spares .
Reviews :
SeByDockY's review
More to come, test video, speed run...
Mar 19, 2016, 04:37 PM
TechTronic9000's Avatar
How is the turning radius ? Can you take sharp turns with it ?
Mar 19, 2016, 05:15 PM
Car Bashing
Jym73's Avatar
I can't tell exactly as i use it during a short time, i won't say it do sharp turn but it isn't too large, will see in the run test video. I hope receive the ball bearing quickly.
Mar 19, 2016, 05:24 PM
OK, looking forward to more tests (after you fix it). By the way any idea how this model stacks against a Subotech ?
Mar 19, 2016, 05:33 PM
Car Bashing
Jym73's Avatar
You talk about Subotch coco? If yes, hard to compare a 1/18 to a 1/24 as 1/18 is bigger.
Mar 19, 2016, 05:44 PM
There is the SUBOTECH BG1506 which is 1:12 (larger), not a buggy but still 4WD.
Mar 19, 2016, 05:48 PM
Car Bashing
Jym73's Avatar
Same, 1/12 is almost the size of 1/10, 1/18, as you can see on the photo in first post is more close to 1/16. The main problem with the Subotech 1/12 is the parts support, hard to find.
Mar 20, 2016, 06:06 AM
OK, now I'm waiting for your ball bearing to arrive.
Mar 20, 2016, 06:22 AM
Car Bashing
Jym73's Avatar
Me too look forward that it arrive.
Mar 20, 2016, 12:02 PM
mike_o's Avatar
I don't understand the ball bearing issue; Was it never there? Or did you loose it while driving?
Secondly; The shock: Can they be - and remain - filled with oil or will the leak?
Mar 20, 2016, 12:17 PM
Car Bashing
Jym73's Avatar
I received the car with a missing ball bearing. Mistake of worker at factory.
I think they can be filled with oil. But to see if they leak i should use them on the car.
Mar 21, 2016, 04:51 PM
Car Bashing
Jym73's Avatar
34$ at US-LA WH, at this price it is interesting.
Mar 22, 2016, 05:24 AM
That's a great price for entering this car related hobby
Mar 22, 2016, 11:09 AM
Car Bashing
Jym73's Avatar
Description:
Mar 24, 2016, 03:59 AM
Where did you get that fine mesh (synthetic tissue) ?
