Mar 11, 2016, 01:20 AM
SeByDocKy's Avatar
Mini-Review
Fei Lun FT011, a 4S 65cm speedboat (under construction)
BEFORE FIRST USAGE, PERFOM SHAFT/BALL BEARINGS INSPECTION TO BE SURE IT'S CORRECTLY LUBRIFIED!!! YOU CAN SERIOUSLY DAMAGED YOUR FT011 IF NOT. DO NOT USE THE FT011 IN SALT WATER !!!!
INTRODUCTION
Why change a success story ? After the success of the FT007, & the FT009 two brushed speed boat and after the pretty cool brushless FT012, here is the giant 65cm member in the Fei Lun familly, the Feil Lun FT011. This "monster" is announced to run at 55km/s thanks to a 4S battery.... Let's have a look to this new beast.
BOX CONTENT
+ 1 x Fei Lun FT011 (with a 4S 2200mAh LiPo with T-dean connecter)
+ 1 x Transmitter (using 6xAA batteries not included)
+ 1 x Charger
+ 3 x Spare props (same size than the FT012)
+ 1 x Boat holder
+ 1 x Grease tube
+ 2 x Allen key
+ 2 x headless hexscrew
+ 1 x Wrench tool
+ 1 x Instruction manual (English)
A nice attitude... the presence of this small tube of grease
Two spare headless hexscrews for the coupler
OVERVIEW
The FT011 is a giant model, the FT012 looks like a dwarf aside.
I really appreciate the carbon paint style of the upper canopy plastic. In general, the plastic quality is the same than former models. Like predecesors, the FT011 uses the same deep "V" shape, known to not be the best design for high speed racers. At very high speed, the boat is partially lift and part of the traction can be lost because the props time to time is out of the water.
-Front view
On front, you have to install the shock absorber part
via the two front holes
With the shock absorber installed
A large close-up
-Side view
The exit of the watersystem is located on the left side
-Rear view
The "backoffice" shows two long orientable plastic turn fines and two horizontal trim tabs stabilizers to guarantee maximum stabilization at full speed.
Like former models, you can remove water without disassembling the double desk system.
Turn fins/water scalpel are longer than FT012 model of course to increase stability... The price will be a poorest manoeuvrability vs the FT012, no free lunch.
-Upper view
-Bottom view
The same structure than the FT012 .
-Weight
With the battery inserted, the boat weights around 1.2Kg ....
Interior
To avoid potential water leak, a double desk system is present like the FT011 but more efficient IMHO. No problem with the battery for example. In another hand, since there is no waterproof powerswitch, you need each time to disassemble/install the two desks... it's really annoying versus time. I regret the absence of a powerswitch.
The outrunner motor, a 2822 model.
Here a rigid shaft system.... It means it's ultra important to grease/inspect the shaft section especially at the coupler part
IMHO, a larger and more powerfull brushless motor would have been a better choice. Maybe with a larger model, the rigid shaft durability would have been deeply impacted
A close up on the the coupler
BE SURE TO REGULARY INSPECT/GREASE THE COUPLER/SHAFT PARTS. Use the provided tube of grease. The shaft system is getting hot in action and it's very important to avoid any extra friction.
A simple 18g servo, maybe a little bit weak to manage at full speed the ruddler control even if I never observed a non-possibility to turn the boat.
Notice the half-loop probably playing the role of shock absorber in the direction pipeline. Another good news, no more the Fei-Lun security system (see FT007, FT009)... This former in practice came fast out of order and was needed to by bypassed.
The 3-in-1 ESC-FC-2.4G receiver combo welcoming a 65A ESC.
All the combo is hot-glued/silliconned as waterproof protection. This protection need to be really well done to avoid any shortcuts even if in practice, I observed very small water leaks not very dangerous IMHO.
Shaft system
Props
The same FT012 prop is installed. So, if ESC can handle a little bit more strange, faster speed can be achieved with a more efficient prop
LiPo
The 4S LiPo monster with a capacity of 2200mAh and a discharge rate of 30C, a pretty powerful LiPo equiped of T-dean connector.
Transmitter
The radio chassis since the FT011 with two analog trims for the throttle and the direction. Good news, I was able to bind the FT012 with the FT011 radio but not the FT011 with the FT012 radio (strange ...)
A solid green LED is here when the pairing is done.
6xAA batteries for the radio... too much IMHO.
In practice, the control range is pretty solid, no sign of lost connexions within a radius of 120m ( I didn't go further). When the transmitter is turn off, the boat cuts the throttle immediatly and if you turn on it again, the pairing is done immediatly, a good news.
FIRST USAGE
For sure, the FT011 is a fast boat thanks to its 4S power. Since the FT011 is pretty heavy, the acceleration are less strong than smaller familly's members and you need a couple of meters more to reach the top speed proportionnaly (IMHO closer to 50km/h than 55 km/h). As expected, with such stabilizers, the manoeuvrability is really worse than a FT007/FT009... it's obvious. Now even at a moderate speed (from 30km/h), you need a diameter of 25m-30m to make a full turn. It means in order to enjoy more your FT011, you need a more open/large water-surface.
EDIT 03/14/16: new demo
Fei Lun FT011 new demo race (Courtesy Banggood) (5 min 9 sec)
Fei Lun FT011 first demo run (Courtesy Banggood) (10 min 50 sec)
Don't be wrong, I really appreciate this boat. The stability is here until maybe at ful top speed where the boat seems to "dance" between each side probably lift by the top speed. The FT011 don't introduce important water leaks that a good news but be aware, after usage all ESC, motors, LIPO and the rigid shaft are getting warm (around 35-40 deg Celscius).
The FT011 have a lot of potential for future moddings. You can of course install a larger brushless motor and swap the prop to a more efficient model. Be sure to check carefully the solidity of the rigid shaft and grease regulary. I won't be surprised to see a FT011 pushed over 70km/h.
CONCLUSIONS
All ingredients of the success story are still here with of course a lot of improvements. I really liked the new design carbon inspired, the efficiency of new double desks system and the amount of power given by the 4S battery. This boat need a wider space due the considerably reduced maneouvrability introduced by the presence of all the stabilizers. I strongly suspect Fei Lun to integrate an underpowered brushless motor to limit the top speed. I guess, the stability is no more guarantee over 55 km/h with this V design and a larger motor. I regret also the absence of basic telemetry feedbacks such as RSSI and LiPo voltage as well as an external powerswitch. With such model, you need absoluptly to inspect/grease regulary the shaft section.
UNBOXING
Fei Lun FT011 unboxing (Courtesy Banggood) (12 min 47 sec)
PROS
+ 4S monster
+ Beautiful design with carbon paint style
+ Up to 50-55km/h
+ Efficient double desk system with few water leaks
+ Self-righting system
+ Radio protocol retro-compatible with the FT012 (but not the inverse)
CONS
- Reduced manoeuvrability (no free lunch)
- No waterproof powerswitch
- No telemetry (RSSI, LVC alarms on the TX)
- Heavy (1.2Kg)
- "Jumping " a bit at full speed
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thank them for this attitude.
You can find it actually for 140USD at http://www.banggood.com/FT011-65CM-2_4G-Brushless-RC-Boat-High-Speed-Racing-Boat-With-Water-Cooling-System-p-1036340.html
Mar 11, 2016, 01:22 AM
SeByDocKy's Avatar
reserved
Mar 11, 2016, 02:01 AM
http://flahut59.over-blog.com/
flahut59's Avatar
Nice!
With a real prop and a better lipo it will be better and faster.
I would like to see a run between the FT 011 and FT 012
Mar 11, 2016, 06:07 AM
SeByDocKy's Avatar
Originally Posted by flahut59
Nice!
Yes can be interesting to race between each other ..
Mar 11, 2016, 08:42 AM
Closed Account
Mar 11, 2016, 11:38 AM
ApexpredatorGT's Avatar
Nice review, thank you for sharing. The carbon fiber styled paint looks really cool and the boat is pretty fast. I don't think there are too many boats that can give that sort of performance for 140$
Mar 11, 2016, 01:11 PM
SeByDocKy's Avatar
I won't be surprized if in a couple of weeks, we can expect a 10-20$ drop ...
Mar 11, 2016, 02:39 PM
simontan's Avatar
Banggood met me halfway on a price match request, so I was able to get mine for $111.
Just wish it would stop raining so I can run it already.
Mar 11, 2016, 02:42 PM
Just Plane Nutts
AirDOGGe's Avatar
Funny how we wait until it's not raining to get our boats wet...
Stormy weather has FINALLY come to Northern Cal, so sitting it out here as well, and glad to do so considering the nasty drought we've been suffering through.
Mar 11, 2016, 05:10 PM
SeByDocKy's Avatar
I am Lucky in South of France, spring is almost in the air
Mar 14, 2016, 08:36 AM
SeByDocKy's Avatar
A new run with the FT011
Mar 15, 2016, 12:20 AM
simontan's Avatar
Nice!
On the other thread I mentioned trying a larger 34mm prop on a 3s pack, and I thought it ran better than with the stock 30mm prop on 4s. Just have the one 4s pack it came with for now, so will have to wait til tomorrow to see if the stock electrics can handle the bigger prop on 4s.
Mar 15, 2016, 11:13 AM
SeByDocKy's Avatar
Well after each of my run, the ESC was not too hot ... so probably it can handle this larger prop. Any link for it ?
Mar 15, 2016, 03:29 PM
simontan's Avatar
This is the prop I tried. I've seen it on ebay as well.
http://www.offshoreelectrics.com/pro...od=cnc-3414250
I did a quick run with it during lunch today, and the good news is stock motor and esc were still barely warm turning the larger prop on 4s. Bad news is the boat would just keep flying out of the water like a flying fish. The problem is I don't have enough experience to know if it's because the water was too choppy or if the boat is simply overpowered with this setup. I gotta say, it's kind of entertaining to see it pop out of the water, land, and repeat all the way across the pond but not real controllable. Anything I can do to correct this? The strut isn't adjustable, and the battery holder is fixed in place so can't really do anything to adjust COG. Only adjustment is trim tabs and turn fins. Would bending the trim tabs down keep it from jumping out of the water?
Also made a noob mistake not gluing some foam to the outer hatch which popped out on me during all the jumping . So dumb. I already had some pool noodle ready to glue to it too but decided to put it off. Luckily the outer hatch is really just for aesthetics, and it still runs fine with just the inner hatch.
Mar 15, 2016, 03:36 PM
SeByDocKy's Avatar
Yes I guess the COG don't let the rear part in good condition to handle this amount of extra power. Even with the original prop, it's jumpy. So in practice you don't really exceed the 55 km/h ?
I didn't glue some foam ... too... Should I ? the locking system seems efficient ....
