Mar 06, 2016, 02:27 PM
chicken nuggets
Pixhawk 2.4.8
Anyone had experience of a Pixhawk PX4 version numbered '2.4.8'?
Several places are advertising them, but there is nothing I can find about them, bar what is in the advertising blurb.
Thanks in advance for any info.
Mar 10, 2016, 05:02 PM
srepfler's Avatar
Love it,
all works, cheap,v3 ( 2 gb).
Pixhawk lite thread
https://www.rcgroups.com/forums/show...3#post34217040
Pixhawk PX4 2.4.8 Flight Controller 32 Bit ARM PX4FMU PX4IO Combo for Multicopters
http://www.banggood.com/Pixhawk-PX4-2_4_8-Flight-Controller-32-Bit-ARM-PX4FMU-PX4IO-Combo-for-Multicopters-p-1040416.html
new pixhawk px4 2.4.8 first view (3 min 12 sec)
56.99$ for now. ( currently 15% off)
Mar 10, 2016, 05:06 PM
srepfler's Avatar
GPS, Telemetry, power module all good.
Mar 10, 2016, 08:58 PM
chicken nuggets
Ahhh excellent. Thank you very much indeed for the info srepfler - much appreciated
Mar 14, 2016, 05:33 AM
I've been trying to figure out what the difference is between pixhawk Version 2.4.6 and 2.4.8?
Mar 14, 2016, 05:53 AM
chicken nuggets
I am thinking it is the 2.4.8 has the chip without the 1MB limitiation. Will know in a few days as I have a 2.4.8 on the way to me.
Mar 14, 2016, 06:03 AM
Awesome. Let me know please. I've been all over the place trying to figure it out.
Mar 14, 2016, 02:18 PM
srepfler's Avatar
It is 2mb version. V3
Mar 14, 2016, 02:30 PM
srepfler's Avatar
EzUHF PPM works like charm.
Will test digital PWM RSSI next.
2.4 telemetry is interesting connect to WIFI and thats it, no plugin receiver.
2.4G Wireless Wifi Telemetry Module With Antenna For Pixhawk APM MiniAPM Flight Controller
http://www.banggood.com/2_4G-Wireles...2310222013070W
Mar 14, 2016, 02:34 PM
Fear regret more than failure.
And you can save an additional 5% right now with coupon: FCNLBG
Mar 14, 2016, 04:02 PM
Hey, thanks for the info and for the coupon. Probably going to order one very soon.
Mar 15, 2016, 08:30 AM
great but what about the range with this module?
Mar 15, 2016, 12:12 PM
Can anybody show inside photo ?
Is this 2.4.6 upgraded to new CPU without 1MB limitation or is this similiar to Pixhawk Lite ?
Mar 15, 2016, 02:48 PM
2.4GHz modules can seriously interfere with 2.4GHz radios... using a 2.4GHz telemetry module is, imho, a recipe for disaster
915MHz (and more so 433MHz, where legal) also have much better obstacle penetration and longer range
There is really no good reason to use a 2.4GHz telemetry module, as far as I'm concerned. Only downsides
Mar 16, 2016, 03:08 AM
srepfler's Avatar
I am using ezUHF 433 LRS system and 2.4 is free.
For video have 5.8 Ghz.
2.4 is probaly 300-500m (standard wifi range) and with external usb wifi dongle with directional antenna can be significantly enhanced.
Main advantage is no receiver part, can use any pc with wifi,
it is cheap 10$, and for first setup and checking good enough, probably better then bluetooth.
Weight and size,size of antenna is definitely plus.
For long distance even 433 or 915 mhz have limited range 1-2 miles (stock antennas), maybe more expensive variants of 250-500mw.
Minim OSD will work good for important info on display.
Downside for 2.4 is not for 2.4 radio, same as wifi cameras if used gopro, runcam 2...
But for first flight's and easy diagnostic, parameter change good enough.
Did not yet succeeded using it on android platform.
At the end it is just another option for telemetry, there are two ports and probably can use
both.
Some countries can not use 915 mhz ( legal reason), and first 433 had range issues due USB did make spikes on 433.
I am planning getting 250-500mw 915mhz version later for better telemetry range.
Sold 2 PixHawk 2.4.8 with accessories for sale Maverickk Aircraft - Electric - Multirotor (FS/W) 1 Mar 28, 2017 12:23 AM
Question What is different on the Pixhawk 2.4.8 from the 2.4.5? TheQuestor Multirotor Drone Electronics 2 Apr 15, 2016 10:43 PM
Discussion pixhawk 2.4.6 vs 2.4.8 itsab67 Multirotor Drone Electronics 3 Apr 10, 2016 07:19 PM
Discussion pixhawk 2.4.6 vs 2.4.8 itsab67 Multirotor Drone Electronics 0 Apr 09, 2016 01:17 PM
Discussion Cheerson CX-20 Zero Tech to Pixhawk 2.4.6 or APM 2.8 flight controller + NEO M8N GPS GTMonster Multirotor Drone Talk 0 Oct 20, 2015 06:47 PM
