Jun 16, 2017, 06:17 PM
I know the info states this app will work with iPad 3rd gen. I was hoping to use an 'old school' iPad 2 - any reason why this may not be suitable?
Jun 16, 2017, 07:39 PM
In search of speed......
Dansy's Avatar
I don't know why.....but I tried the apps does download fine.....but it won't connect to the bump....bummer because I have an iPad in my trailer for music....also use for my guitar pedal system....
Jun 16, 2017, 07:51 PM
Unfortunately, iPad 3rd gen was the first version to support Bluetooth Low Energy which is required to connect to the Bump Controller.
Technically, you could upload history to your BT/LE-enabled smartphone (or any other device) and sync it to DropBox for viewing on the iPad 2nd gen, but we can't guarantee support/performance. If you already purchased the app for another Apple device, then there's no cost in trying to see how it works on other older Apple hardware, but we won't be putting resources on fixing bugs that are specific to older hardware.
Jun 16, 2017, 07:54 PM
What device/os are you attempting to connect with ?
Do you see any popups on the Bump Controller about "Bluetooth connecting" ?
By "won't connect" do you mean you see it in the list when you Scan, but aren't able to connect ? .... or it doesn't show up at all ??
Jun 16, 2017, 07:56 PM
Originally Posted by Beckler
Revokelly any thoughts on the above? I just tried it again and even changed the supply battery type to Car AGM 95%DOD set to 10.5V limit (which it is - tho I had it set to AGM50dod before), but it didn't make any difference.
I'm going to test this myself and let you know.
I assume you're running latest firmware on both Bump and Powerlab ?
Jun 16, 2017, 08:38 PM
Thanks Kelly,
I was kinda hoping that the 2nd gen would work - bugger.
Oh well, I do have an android tablet that will work so I guess I'll pay for the android app as well.
Jun 17, 2017, 08:09 AM
Beckler's Avatar
Ok thanks. Yes both are the latest I think, Bump 3.12 and Dual PL 1.10.
Jun 17, 2017, 05:26 PM
Dansy's Avatar
2 different bump controller latest software.....PL8 and DPL8 each with their own boxes and power supply ect....
It show up but doesn't give the option to connect.....that's ok I just have to either used my iPhone or bring my 12" iPad Pro.....
Jun 19, 2017, 12:21 PM
FYI - Just applied for public release of Apple iOS CCS 1.16 with the above features, so you should see it available soon.
Update - we found a bug 1.16 which could potentially corrupt BumpTags when using the New BumpTag wizard from the iOS app, so 1.16 was held and now 4.02 (with the fix) has been submitted to Apple for release. It should post to public in the next day or two.
// Version 4.02
// BUGFIX: New BumpTag wizard sometimes fails to write tag
// Version 4.01
// FEATURE: Version number synced-up with latest Android "universal" app version
// FEATURE: Cycle graph export to CSV (to DropBox /export directory)
