This thread is privately moderated by JBone, who may elect to delete unwanted replies.
Mar 04, 2016, 04:57 PM
Trader Rating: 33
$210.00 USD
Seller Pays Shipping
Sold
FPV Goggles, VTX, and Camera combo
Hi All,
I have FPV Goggles, VTX, and Camera combo up for sale.
Goggles:
Boscam GS920 2.4Ghz/5.8Ghz FPV AIO Goggles (Band A)
I tried these goggles and the FatShark Attitude SD V2, and decided that I liked the Boscams better, so I returned the Attitudes. I have used these goggles for about 1.5 years, but recently purchased the FatShark Dominator V2 FPV Goggles (mainly for the built in DVR), so I no longer need these goggles. Note that I trimmed up the nose area so that the goggles would fit better. This is a very common mod to this model, and glad I made this mod, as there is less light leakage, and the goggles are more comfortable.
Specs:
Display resolution: VGA 640x480RGB, 922k pixel color display
Field of view: 32o diagonal
Virtual image size: 48 inches diagonal at 2m
Wireless receiver frequency: 2.4G Hz 8-channel,5.8GHZ 8-channel
Antenna connector: RP- SMA
Power supply: 8-13V, 300mA
Weight:158g (goggle only)
5.8Ghz Channels (A Band) 5865,5845,5825,5805,5785,5765,5745,5725
Also receives 8 Channels on the 2.4Ghz band
Includes:
1 x Boscam GS920 Glasses
1 x JR cable
1 x FUTABA/9XR cable
2 x Antenna (2.4Ghz/5.8Ghz)
1 x AV cable
1 x 850mAh, 2cell lipo.
Link for more details (Note that this page is the Band E model, mine are Band A)
Camera
The camera is brand new in the box. I have this same camera on my 250 quad, and it works great.
Specs:
Brand Name: Eachine
Item Name: Camera
Power Supply : 3.6-5.5V
Power Consumption : 60mA @5V
Sensor : 1/3" CMOS
Format : PAL, NTSC One-key Switchable
Resolution : HD 700 TVL
Working Temp.: -20 to 70℃
Camera : 32 X 32 X 23.5mm
Lens (Length x diameter) : 15.3mm X 14mm
Weight : 12g
Features:
148°FOV
160°DFO
Package Included:
1 x Camera
1 x Power Cable
1 x 5 Pin Cable
Link to product page.
VTX
This is a used VTX that I used as a 1.3Ghz to 5.8Ghz relay. I zip-tied a small fan and spacer to it, to insure it never got too hot while stationary. Its never been in the air, and has only been used a handful of times. The cable I have does not have an audio lead.
Specs:
Brand Name: Eachine
Item Name: Transmitter Module
Item NO.: TS5823
Modulate: Wideband FM Modulate
Video Format : NTSC/PAL
Output Impedance:50 Ohm
Output Power : 23-24dBm
Channel:32 CH
Operating Voltage: 7V-24V
Supply Current : 190mA
Operating Temperature: -10~85
Video Band Width : 0~8.0 MHz
Audio Carrier Frequency : 6.5 MHz
Video Input Level: 0.8~1.2 Vp-p
Video Input Impedance : 75 Ohm
Audio Input Level : 0.5~2.0 Vp-p
Audio Input Impedance : 10K Ohm
Connector: RP-SMA Female(center needle)
Dimension: 40mm x 23mm x 8mm
Weight: 10g
Features:
32 channels
200mW RF power output
Package Included:
1 x Transmitter Module
1 x Antenna
Mar 05, 2016, 01:55 AM
Trader Rating: 0
Kattywampus
boscam goggles.
I am from MPLS. Interested in goggles. Can look at them in the morning. Thanks! I have a wide eyes so please contact me.
