Mar 09, 2016, 08:59 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
When I redrew this one from the original plans, I lengthened the nose a little thinking that as it was originally designed for a much heavier glow motor
Seems I was a bit out with my thinking as it needs the battery well back behind the C of G to get it to balance.
I have decided to leave it alone so it will be able to take a very small battery if preferred
Lockey
Mar 09, 2016, 09:24 AM
justj's Avatar
I've been following ALL your planes! Will continue to.....
Think I'll build this one.... with the V-tail!
Bob,
Let me know when you are ready to cut one for me!
Jerry
Mar 09, 2016, 09:30 AM
Lockey's Avatar
Bob ... Cherry Bomb file sent
Lockey
Mar 09, 2016, 09:39 AM
Thanks Lockey, looks like a fun one
Mar 09, 2016, 09:53 AM
Lawn Dart Flyer's Avatar
Great looking plane Lockey. Can you post it specs for us? The control surfaces look HUGE, I bet you'll need to be a ninja on the sticks on the maiden.
Mar 09, 2016, 02:43 PM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
You-da-man! Lockey. Does the prop clear the grass?
Mar 09, 2016, 03:19 PM
Retired CAD guy
birdofplay's Avatar
ER umm aaa, OK JJ !
I haven't even started yet. .
But Soon very soon :>}
Mar 09, 2016, 04:05 PM
Retired CAD guy
birdofplay's Avatar
OK ?
What Material do you want this cut from ?
6mm Depron
Model plane Foam
Dollar Tree White or Black
Posterboard covered Foam. Very strong, No peel off smooth surface but also Heavier.
Lets get those Votes IN folks !
This IS an election year afterall ! ! !
Mar 09, 2016, 04:07 PM
randynsaudi's Avatar
way to many in line to build....just got the little bipe cut out....
Mar 09, 2016, 04:19 PM
justj's Avatar
Originally Posted by birdofplay
OK ?
6mm Depron
Just let me know!
Jerry
Mar 09, 2016, 05:00 PM
Lockey's Avatar
Duke, prop should clear the grass, not by much but I would think it will be in the air in about one metre or 2 ... either that or it will make a good lawn mower
I used 6mm Depron for mine, if you are using foam board or any 5 mm board, make the formers a couple of mm wider and a mm longer and the slot for the wing a little narrower too
Wing span: 985mm (38.75 " )
Length 855mm (34.6inches)
Material: 6mm Depron or MPF (approx one and a half full sheets) 1000 x 700 sheet
Servo’s: 3 x HXT900 9g (or similar)
Motor: D2826-6 ... 2200kv Outrunner Motor (or similar)
ESC: TURNIGY Plush 40amp Speed Controller (or similar)
Prop: 6x4E propeller (or similar)
Estimated weight: 500 - 550 grams (17.6 – 19.4 oz) with 1500 battery
Remember ... as usual, if you build only request is that you post pics of your build and if possible a video or two
Lockey
Mar 09, 2016, 05:23 PM
Very nice build, and great photo description. Question on the battery though, does it go all the way back in the photo you showed?
Also where is the CG on this.
Mar 09, 2016, 05:55 PM
Lockey's Avatar
Yes battery needs to be back there (I think) to achieve the correct C of G .. I was very surprised
According to the original plans, this is where the CG is (see pic) which is where I have the CF spar
You are more than welcome to check it for me if you want to
Lockey
Mar 09, 2016, 06:40 PM
This will definitely be in my lineup of builds, I have a couple kits that I bought from Bob (Birdofpley) that I received today, then will start this one.
Lockey
Mar 09, 2016, 06:43 PM
Dukejet's Avatar
Cool Lockey, It will be easy to angle the fuse back a bit more to get the prop out of the grass.
ie- make a line from the back of the wing on the side of the fuse through to just under the elevator servo and she should sit up nice??
Did someone say V-TAIL!!! LOL..
