Mar 03, 2016, 01:14 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Cherry Bomb and Cherry Bomber EDF
Hi Guys
Here's one that we found in an old magazine and thought it might be a nice one to build in Depron (or foam board)
I made the fuselage a little higher in the hope that it can be a SOG
I used 6mm Depron for mine, if you are using foam board or any 5 mm board, make the formers 2mm wider
Specs:
Wing span: 985mm (38.75 " )
Length 855mm (34.6inches)
Material: 6mm Depron or MPF (approx one and a half full sheets) 1000 x 700 sheet
Servo’s: 3 x HXT900 9g (or similar)
Motor: D2826-6 ... 2200kv Outrunner Motor (or similar)
ESC: TURNIGY Plush 40amp Speed Controller (or similar)
Prop: 6x4E propeller (or similar)
Estimated weight: 500 - 550 grams (17.6 – 19.4 oz) with 1500 battery
Plans are now available at: http://www.lockeysrcplans.com
Lockey
Mar 03, 2016, 08:54 AM
Retired CAD guy
birdofplay's Avatar
Say that's an oldy but a goody !
I recall seeing that one as I have a big collection of old RCM mags.
I also HOPE it'll slide on ground for take offs.
You are starting to amass quite a repertoire of designs.
Good show :-)
Bob
Mar 03, 2016, 09:00 AM
Lockey's Avatar
Hey Bob, goods to see you mate, let me know if you want any of the files
Lockey
Mar 03, 2016, 09:27 AM
I will give this one a try.
Mar 03, 2016, 09:51 AM
When cows fly!
Looks like a nice simple design! Hmmmm, I am pretty sure I could still crash it! Needs a rudder! And a fast motor
Mar 03, 2016, 11:52 AM
Retired CAD guy
birdofplay's Avatar
Locky , if you send it I will add it to the long list of your designs that I offer a cutting service for
You're always so generous with your creations.
Bob
Hoosier Cutout Service
OK OK OK :-||| g,g,g,g guess what my b,b,b,b,background music will be for this vid
give up ?
http://www.bing.com/videos/search?q=...VDFSRV&fsscr=0
Mar 04, 2016, 08:16 PM
Laughs at un-boxing videos...
basicguy's Avatar
My wife started with a slinger fuselage cut out and then we put on a delta wing and Vtail. Looks a lot like your plane. Runs great, can tolerate a lot of power. I have a 12" prop on mine so can't belly take off. Landings are super stable.
Yours should run great.
Mar 04, 2016, 08:32 PM
Lockey's Avatar
Looks great basicguy, V tail looks nice ... must try a V tail one day
Sounds like your wife is one clever lady .. wish I could find a lady with some aero-modelling skills and interest ... any takers
Lockey
Mar 04, 2016, 09:46 PM
basicguy's Avatar
Me thinks I have one of a kind.
Mar 04, 2016, 10:00 PM
Lockey's Avatar
Is that the model or the Lady ... me thinks "the lady" you are a lucky guy
Lockey
Mar 09, 2016, 07:32 AM
Lockey's Avatar
More build, all up to this stage I have spent about 6 hours (including cutting out) I have made a few mods to the plans / patterns so would recommend downloading the new plans before building
If you don't feel confident rolling over the KFm airfoil, simply cut it off and glue it on top and then sand the leading edge ... I cocked mine up and had to cut it off and glue and sand the leading edge
Lockey
Mar 09, 2016, 07:42 AM
That is a really cool plane
Mar 09, 2016, 07:54 AM
Lockey's Avatar
Thanks pb, hope she flies good too
Lockey
Updated MK2 plans
