Feb 28, 2016, 08:37 PM
Is their room for 2 3s batteries in FMS 1700 mm Corsair
I have looked and can not find anything the forums.
Question is their room for 2- 3s batteries wired to make 22.1 v in a FMS 1700 mm Corsair?
I have a bunch of 3s batteries and would not like to buy 6s ones.
Just wondering
Thanks for any advice
Feb 28, 2016, 08:49 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
These are the dimensions for the recommended 6S battery for that plane :
Length
137mm / 5.4in
Width
45mm / 1.77in
Height
51mm / 2.0in
If you have two 3S batteries that ( when stacked one on top of the other ) will have the same dimensions , it should work . But don't forget you'll need space for the series harness .
Feb 29, 2016, 11:34 AM
E-Challenged's Avatar
The two packs will probably weigh slightly more than a single 3S pack of the same capacity, this may make the model more nose-heavy. Check the CG setting and add a little weight to tail if needed.
Mar 02, 2016, 04:24 PM
Thanks guys
